Need help figuring out pins using someone elses code?
Hi guys I am using Steve Denson prop code for the Atmel AT45DB161D.. I have been trying to figure out what pins he is using in his code, The closet thing I have figured out using my scope is , prop Pin 0 to Ram pin 8 SO... Prop Pin 8 and 9 to I don't know I am not sure these are even the pins to use is there a way anyone can show me how to figure what pins are connecting to what when I am reading someone else code? If it was pure Spin I think I could do it dira outa stuff like that but I am lost reading this code and I am pretty desperate to see if this Ram chip will work I am attaching Steve's code and the data sheet thanks for any help. I do use quite a bit of sample code from Obex so if I could understand how to figure out pin usage it would be a real big help
Steve if you see this I hope you don't mind me posting your code I tried to search for your name but came up empty.
Post Edited (mikediv) : 12/7/2009 2:14:24 AM GMT
txt
102K
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
You can enable the demo if you add ' before { above the '' begin test code line. Other code can be enabled ... YMMV.
