[resolved][puzzle] jumping counter
kuroneko
Apologies if this is common knowledge but I just found out about it and share it anyway [noparse]:)[/noparse]
What's the result returned to the caller (through par) in the following code fragment and what label does it jump to (:_5, :_6 or :_7)?
For example, (%1000_0111 and :_7) would be a valid - but wrong - answer. Solution: label :_5, result $85. Who would have guessed [noparse]:)[/noparse]
Also, don't be scared about anything before jmp cnt. The reason for having this code in there is to make sure that the lower 9 bits of cnt are 0 or slightly higher but in a controlled range. A waitcnt vscl, #0 would have done the job just as well but depending on clock speed might take a while (therefore the imposed limit of 257..512).
Note: jmp cnt/phsx is confined to one of the jump targets :_5, :_6 or :_7, i.e. it doesn't go off into nowhere.
For people uncomfortable with waitcnt & Co here a version with ordinary counters. Functionality is the same.
Post Edited (kuroneko) : 12/9/2009 6:03:13 AM GMT
DAT org 0
start movd cnt, #2 ' get some room
add cnt, cnt ' min 257 cycles
andn cnt, #%111111111 ' max 512 cycles
waitcnt cnt, #0 ' wait for $XXXXX(%xxx0)00
jmp cnt
:_5 add outb, #%001
:_6 add outb, #%010
:_7 add outb, #%100
or outb, #%10000000 ' indicate result ready
wrlong outb, par
cogid cnt
cogstop cnt
fit
DAT org 0
start movi ctra, #%0_11111_000
mov frqa, #1
mov phsa, #3
jmp phsa
nop
:_5 add outb, #%0001
:_6 add outb, #%0010
:_7 add outb, #%0100
or outb, #%10000000
wrlong outb, par
cogid cnt
cogstop cnt
fit
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Once again, not to spoil it, answer attached.
So far, 2 views to my previous answer - one is kuroneko and one is me
Post Edited (kuroneko) : 12/7/2009 5:15:33 AM GMT
Then, Propfest tonight on the Gold Coast, Australia
But I do not want to know the answer. Only that it's wrong.
Graham
There are some guesses here for the timing diagram.
I think I just made a simple error (not really part of puzzle perhaps)
Graham
Graham
Bare in mind I was trying to do this from the datasheet without ever having seen the thread where this is a hot topic [noparse]:([/noparse] [noparse];)[/noparse]
Graham
Square one means learning boolean logic again? [noparse];)[/noparse] Nice teaser Kuroneko. Got any more?
The waitcnt (which means all waitxxx instructions) got me. Using the mov instructions was no problem to calculate since Chip disclosed how they work on the other thread.
However, I still need to get the waitxxx understood. I had thought that waitxxx took a minimum of 6 clocks because it causes a pipe flush but this just does not work as I expected. I will seek clarification from Chip.
Anyway, there are only 7 possible answers left, any takers?
Post Edited (kuroneko) : 12/8/2009 12:50:56 PM GMT
Not to spoil it for anyone, But, even armed with all the info I would never have guessed the outcome.
I believe I have deduced the reason it works this way, together with the "unintended feature" and solution·
Whether you are using cnt, phsa, or whatever, the compiler sees this value as a constant... because cnt is always moving and your actually writing to a mask you must do a few strange things with the waitcnt before it syncs up to a value that works for you. ...And in the case with phsa... if you don't start ctra, the jump location becomes more predictable for you.
You could just as easily use a constant for the jump and just see how the jump really relates to where the PC (Program Counter) ends up executing the next instruction.
Example uses the Propeller DEMO board LEDs
[b]PUB[/b] start [b]cognew[/b](@PASM, 0) [b]DAT[/b] PASM [b]jmp[/b] #1 '<--- #0 :_5 [b]add[/b] [b]outb[/b], #%001 '<--- #1 :_6 [b]add[/b] [b]outb[/b], #%010 '<--- #2 :_7 [b]add[/b] [b]outb[/b], #%100 '<--- #3 [b]or[/b] [b]outb[/b], #%10000000 '<--- #4 '-------------------------------------------------------- [b]mov[/b] [b]dira[/b], LEDmask '<--- #5 [b]shl[/b] [b]outb[/b], #16 '<--- #6 [b]mov[/b] [b]outa[/b], [b]outb[/b] '<--- #7 EndlessLoop [b]jmp[/b] #EndlessLoop '<--- #8 LEDmask [b]long[/b] %00000000_11111111_00000000_00000000▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔▔
Beau Schwabe
IC Layout Engineer
Post Edited (Beau Schwabe (Parallax)) : 12/9/2009 7:24:29 AM GMT
