Syntax questions
hello,
1.· when one goes to help, searches "case", the help section notates it with a # sign preceeding it. But when you examine the qtis boe bot example of code, the # sign does not appear. can someone explain the meaning of the # sign if it is not being used in code.
2.· also, the typical code i learned for moving a servo is as follows:
pulsout 13, 750
pause 20
BUT, the qtis boe bot example of code again simply gives the following:
case %1101
pulsout 13, 750
and it neglects the 20 ms pause. albeit, this code is for a constant rotating servo if that makes a difference.
any constructive comments will be appreciated
The smarter I get, the more I understand I don't know!
pulsout 13, 750
pause 20
case %1101
pulsout 13, 750
The plain CASE statement is also described in the Help file of the IDE. Look under "Select Case".
The repetition rate is somewhat flexible and depends on the particular servo used. If there is lots of programming between refreshes , a specific PAUSE may not be required.
The continuous rotation servo may, indeed, be less sensitive to pulse repetition rate.
Cheers,
Tom Sisk
http://www.siskconsult.com
