AD5220 controlling PWM with 555 and BS2
Here is a schematic of My "Tank-Bot" It uses a 555 and AD5220 as a BS2 controlled PWM circuit to send clock pulses to the enable inputs of an L298 dual H-bridge motor driver.
At the beginning of the program I reset the AD5220 to the A position which results in an almost 0% duty cycle. Using this little bit of code.
Then using this code...
This works fine with the motors accelerating smoothly as the resistance of the ad5220 from W1 to B1 decreases and the duty cycle increases.
Then the motors slowing down as the opposite happens.
Problem is when I run the below pre-programmed type code It acts erratically speeding up to full speed at random times or slowing down.
Batteries are fresh and the bug seems to have no real pattern. If I redo the program right after it may show different symptoms or none at all.
I think I may need a large capacitor across the power lines of select chips to prevent the motors turning on at speed 10 from a stop possibly overloading the MCU....idk.
Anyone spot any obvious problems?
Thanks!
Post Edited (Campeck) : 12/6/2009 8:42:36 PM GMT
HIGH UD 'move wiper toward A side PWM CLK, 255, 127
' What's a Microcontroller - DigitalPotUpDown.bs2
' Sweep digital pot through values.
' {$STAMP BS2}
' {$PBASIC 2.5}
'-----------------------------------VARIABLES
counter VAR Byte
'-------------------------------DEFINE OUTS DIRS------------------
OUTS = %0000000000000000
DIRS = %1111111000100110
'----------------------------------------RESET AD5220-------------------------
HIGH 11 'move wiper toward A side
PWM 12, 255, 127 'apply 127 position changing clock pulses
'This program resets the AD5220 to the full A side for 0% duty cycle. then goes from tap 0 of the ad5220 and makes its way up to tap 127
moving one tap every 10ms or so. Therefore increasing motor speed. Then it counts down.
'-----------------------INITIALIZE MOTOR DIRECTION---------------------------------------------
OUTS = %1100000000000010 'bit 15 = 555 control, bit 14 = left track forward, bit 1 = right track forward.
'------------------------------ACCELERATE----------------------------
DO
LOW 11 'set wiper to move toward B side of ad5220.
FOR counter = 0 TO 127 'count from 0 to 127
PWM 12, 255, 1 'pulse CLK pin of ad5220 1 time then
PAUSE 10 'then wait 10 ms
NEXT
'------------------------------DECELERATE--------------------------------------
HIGH 11 'set wiper to move toward A side of ad5220
FOR counter = 127 TO 0 ' count down from 127
NEXT
LOOP
' {$STAMP BS2}
' {$PBASIC 2.5}
DIRS = %1111100000100110 'set all pins with wires attached in schematic to outputs.
' -----[noparse][[/noparse] Variables ]----------------------------------------------------------
address VAR Word ' Stores EEPROM address.
instruction VAR Word ' Stores EEPROM instruction.
DPold VAR Byte 'store digital pot position old 0 - 127
DPnew VAR Byte 'store new position for digital pot. 0 - 127
DPset VAR Byte ' store calculated difference and apply pulse to ad5220
newspeed VAR Nib ' store value 0 - 10 as pulled from EEPROM by instruction
oldspeed VAR Nib 'store old valuse of 0 - 10
UD PIN 11
CLK PIN 12
_555 PIN 15
SPKR PIN 5
' -----[noparse][[/noparse] EEPROM Data ]--------------------------------------------------------
DATA 5,"FFPBBP",6,"FFPBBP",7,"FFPBBP",8,"FFPBBP",9,"FFPBBP" ,10,"FFPBBPQ" ' Navigation instructions.
' -----[noparse][[/noparse] Initialization ]-----------------------------------------------------
PWM CLK, 255, 127
FREQOUT SPKR,200,3200
FREQOUT SPKR,200,3700
FREQOUT SPKR,200,4200
PAUSE 2500
' -----[noparse][[/noparse] Main Routine ]-------------------------------------------------------
'This program looks in the DATA and if Its a number it compares it to the last number and scales the numbers to 0-127 from 0 - 10
'and then gets the difference which it pulses to the AD5220 Which changes the duty cycle of the PWM of the 555. With this setup
' The tank can not make sweeping turns. A future design will have two 100k digital pots controlling a 556 for the two tracks. I burned up one
'AD5220 by using a 220ohm resistor on the AD5220 W1 input instead of a 2.2k , Which caused 20 mA to flow through something rated at no more than 5. oops.
'If the DATA is a Letter it sees which routine to call. And each routine turns the corresponding direction control pins on the L298 chip on.
DO UNTIL (instruction = "Q")
READ address, instruction ' Data at address in instruction.
address = address + 1 ' Add 1 to address for next read.
SELECT instruction ' Call a different subroutine
CASE "F": GOSUB Forward ' for each possible character
CASE "B": GOSUB Backward ' that can be fetched from
CASE "L": GOSUB Left_Turn ' EEPROM.
CASE "R": GOSUB Right_Turn
CASE "N": GOSUB BRight_Turn
CASE "V": GOSUB BLeft_Turn
CASE "P": GOSUB pause_
CASE 0 TO 10: GOSUB speed
ENDSELECT
LOOP
DIRS = %0000000000000000
END ' Stop executing until reset.
' -----[noparse][[/noparse] Subroutine - Forward ]-----------------------------------------------
Forward:
OUTS = %1100000000000010 ' Forward subroutine.
PAUSE 500
RETURN
' -----[noparse][[/noparse] Subroutine - Backward ]----------------------------------------------
Backward:
OUTS = %1010000000000100 ' Backward subroutine.
PAUSE 500
RETURN ' Return to Main Routine loop.
' -----[noparse][[/noparse] Subroutine - Left_Turn ]---------------------------------------------
Left_Turn:
OUTS = %1000000000000010 ' Left turn subroutine.
PAUSE 500
' -----[noparse][[/noparse] Subroutine – Right_Turn ]--------------------------------------------
Right_Turn:
OUTS = %1100000000000000 ' right turn subroutine.
PAUSE 500
RETURN ' Return to Main Routine section.
' -----[noparse][[/noparse] Subroutine – BRight_turn ]--------------------------------------------
BRight_Turn:
OUTS = %1000000000000100 ' right turn subroutine.
PAUSE 500
' -----[noparse][[/noparse] Subroutine - BLeft_Turn ]---------------------------------------------
BLeft_Turn:
OUTS = %1010000000000000 ' Left turn subroutine.
PAUSE 500
pause_:
PAUSE 1000
RETURN
speed:
LOW _555 'turn off 555 for speed calculations
newspeed = instruction ' save 0 -10 value of instruction to newspeed
DPnew = newspeed */3270 ' scale 0 - 10 to 0 -127
DPold = oldspeed */3270 'scale 0 - 10 to 0 -127
IF (DPnew) > (DPold) THEN 'figure out which one is bigger
DPset = DPnew - DPold ' find difference and save value
LOW UD 'set wiper to move toward B side to increase duty cycle
PWM CLK, 255, DPset ' apply # of pulses to CLK pin of AD5220
oldspeed = newspeed ' save value of newspeed as oldspeed
ELSEIF (DPold) > (DPnew) THEN 'figure out which one is bigger
DPset = DPold - DPnew ' find difference and save value
HIGH UD 'set wiper to move toward A side to decrease duty cycle
ELSE 'else do nothing
ENDIF
RETURN
Thanks!
Post Edited (PJ Allen) : 12/8/2009 1:15:45 PM GMT
Let me try that....
I'm not too sure what going on. But all my code isn't showing up in the folder I put it in. when I look for it with the attachment manager or with file explorer. But the stamp editor shows all of them.
Post Edited (Campeck) : 12/8/2009 6:48:29 PM GMT
I remember reading that the PWM command isn't a true Squarewave with a dutycycle. But a highspeed stream of 0's and 1's
That over the time period equals the duty cycle.
So I was wondering if this was affecting the AD5220 in that it wasn't seeing a clean pulse with the PWM command.
Which I had put in in favor of a FOR...NEXT loop.
But With this new speed calculation code preliminary checks indicate the code is clean of bugs.
speed: newspeed = instruction DPnew = newspeed */ 3270 IF DPnew > DPold THEN LOW UD FOR counter = DPold TO DPnew PULSOUT CLK, 1 NEXT DPold = DPnew ELSEIF DPold > DPnew THEN HIGH UD FOR counter = DPnew TO DPold PULSOUT CLK, 1 NEXT DPold = DPnew ENDIF RETURNPost Edited (Campeck) : 12/9/2009 7:39:18 AM GMT
