Linux challenge. — Parallax Forums
Linux challenge.
BradCBradC Posts: 2,601
edited 2009-12-11 18:31 in Propeller 1
This has come from the Catalina thread.. I thought I'd start a new one rather than continue it there.
RossH said...
Careful - if you make it sound too challenging then someone is bound to do it just to prove you wrong smile.gif
It wouldn't be any sillier than some of the other crazy things we do in this forum.
Not only do I super double dare you, but I'll personally donate $1000 USD worth of Parallax credit to the first person who gets Linux running on a Propeller based XMM board that I can buy either off the shelf or from a forum member for less than $200USD.
To keep it simple, the only requirements are
- A tty (serial port will suffice)
- MMC/SD block device containing a standard Linux filesystem of your choice (personally I'd choose minix/ext2 as they are the easiest. FAT does not qualify as it misses out on all the POSIX attributes.
- BASH must run compiled and unmodified from source (no port IO hacks or anything of that nature)
- BASH must be able to spawn sub-processes (fork/vfork)
- The code must be running on the bare propeller. No emulating another processor (MIPS for example).
This means you will have to define a new architecture in the kernel :
brad@bklaptop2:/tracks/linux2/arch$ ls
alpha  blackfin  h8300  Kconfig  m68knommu   mn10300  s390   um
arm    cris      i386   m32r     microblaze  parisc   sh     x86
avr32  frv       ia64   m68k     mips        powerpc  sparc  xtensa
.. and have it build for the native Propeller.
I want to see the kernel boot over a serial port and be dropped to a BASH prompt. I must be able to run text BASH scripts from the SD card and spawn child processes.
This is what I would consider a completely minimalist Linux system.
To qualify this a little, I have absolutely no interest or use for such a system, but for 2 years now people have been banging on about self-hosting systems, *nix on the prop and so forth, so this challenge is a bit of a PUOSU, but with a small financial incentive.
If you always do what you always did, you always get what you always got.
«13
  • RossHRossH Posts: 5,735
    edited 2009-12-06 07:58
    @BradC,
    I admire a man who has the courage of his convictions!
    For myself, I'd never bet money against the Prop (or the people in this forum) being able to do something turn.gif
    Ross.
    Catalina - a FREE C compiler for the Propeller - see Catalina
  • cgraceycgracey Posts: 14,297
    edited 2009-12-06 08:13
    And Parallax will match BradC's $1000 USD offer.
    BradC, you're going to have to serve as judge here, in case anybody comes up with anything. As Jazzed pointed out, I can't even escape Windows (though I'm capable of throwing the PC through the window and running it over with a tractor).
    Chip Gracey
    edited 2009-12-06 08:50
    Nice offer Brad & Chip...
    Pitty I know nothing about unix of any flavor - I wrote mini emulation on a 486 33MHz (written in 486 asm) and ran under unix (possibly SCO?). A friend helped me launch the program on unix. I thought the disk was FAT16 though???
    BTW Chip: It's not your pc you want to throw thru' the window, it's the o/s. LOL
    · Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
    · Search the Propeller forums·(uses advanced Google search)
  • jazzedjazzed Posts: 11,803
    edited 2009-12-06 09:04
    Oh my. I must be in big trouble now.
    BradC, for standard Linux one needs 4MB just for the kernel and 8MB to do anything useful. Now that is possible with two Propellers, but building Linux requires a GNU compatible tool chain. ICC is nice, but it dang sure ain't GNU .... The C99 extensions are not likely to appear overnight in any LCC based tool chain, but that's the minimum of what it would take. I guess running bash as slow as molasses does not disqualify the solution [noparse]:)[/noparse]
  • BradCBradC Posts: 2,601
    edited 2009-12-06 09:20
    jazzed said...
    Jazzed, I well know all the roadblocks currently preventing from this happening. I actually feel my cash is fairly safe.
    I was actually about to post a qualification about speed. It's irrelevant. I don't care if it takes 5 minutes to boot the kernel and 10 seconds to display a directory listing. As long as it runs properly.
    There are two issues I see as the main hurdles. Firstly your toolchain needs the GNU extensions. Secondly you need to be familiar enough with the internals of the kernel to be able to actually define a new architecture and write enough basic drivers for it to make it boogie as described in the top post.
    I didn't make this challenge lightly, and as it currently has no limits, I feel I should impose some.
    This challenge is valid until 6th Dec, 2011 and only on the Propeller-I (although you may use more of them if you need to).
    edited 2009-12-06 09:28
    I'm a kernel diver [noparse]:)[/noparse] It's been a while since I got wet though (2.4x13). I have too much to do this month already [noparse]:)[/noparse]
  • heaterheater Posts: 3,370
    edited 2009-12-06 10:26
    One could start from the sources of Embeddable Linux Kernel Subset, ELKS. elks.sourceforge.net/introduction.html
    From the intro:
    "ELKS currently runs on IBM Personal Computer compatible systems. On this architecture, the ELKS kernel image needs about 200K, and a full running system should require between 400K and 512K of RAM."
    So:
    RAM no problem.
    Disk driver is probably straight forward to hack for SD card access.
    Serial driver for the console should be easy.
    Virtual memory not required. The 8086 IBM PC does not support it.
    I think I read somewhere that this did actually compile with other than GNU tools. Can't find where I read that now.
    The ELKS project does not seem to have been active since 2006 but it looks like it does work.
    Starts to look possible...
    Brad, What's with the "BASH ... from unmodified sources" requirement? That seems a bit of a heavy and unnecessary requirement for a small embedded system. There are many shells to choose from.
    Post Edited (heater) : 12/6/2009 10:32:12 AM GMT
  • ForrestForrest Posts: 1,341
    edited 2009-12-06 10:29
    jazzed said...
    FYI here's some info to run Linux in 1 MB from Flash memory sites.google.com/site/bifferboard/
    edited 2009-12-06 10:32
    Linux does not have to be big. I used to boot it off of two floppy disks. One for the kernel and one for the initial RAM disk. Enough to get into a shell with a few tools.
    edited 2009-12-06 10:38
    heater said...
    Runs on my MIPS router and my Arm iPAQ. As far as I'm concerned that is a good indicator of a reasonably complete, POSIX compliant system.
    The challenge is for Linux or uCLinux. If you properly implement either of those with the right toolchain, you get BASH for free. ELKS is not Linux.
    heater said...
    I used to do it on a single disk often, tomsrtbt still does. I only own two machines with floppy drives these days, and that's only because my day to day jukebox machine can't boot off USB or CD.
    edited 2009-12-06 10:43
    Forrest said...
    Nice link Forrest. I have 1MB XMM on my desk now and could go to 2MB if forced. No GNU though.
    I ran Linux startup from 1.44MB floppy ... 10 years ago. I'd bet that was compressed.
    edited 2009-12-06 11:02
    BradC: "ELKS is not Linux".
    Isn't it?
    If it's derived from an original Linux source tree then surely it is Linux as much as uCLinux or what ever RedHat gives you.
    Or is the rule that we have to start from a source tree directly from Mr Torvalds himself?
    Time to peek into the ELKS sources and check ...
    edited 2009-12-06 13:18
    heater said...
    Isn't it?
    No, it's not.
    heater said...
    It's not.
    heater said...
    Any 2.6 series kernel would qualify, given it has been available for about the last 5 years, or whatever is current in the next 2 I guess. Source from www.kernel.org.
    ELKS was a ground up project with enough parts of an early Linux kernel grafted on to enable userspace code to be roughly source compatible with real Linux. It's a hack. A clever hack, but a hack. It's not Linux.
    If you get the toolchain working, uCLinux will run comfortably on small memory, MMU-less systems.
  • AleAle Posts: 2,363
    edited 2009-12-06 14:08
    Well,
    who starts porting gcc to the prop then ?
    The real problem is that the nice trick:
        jmp #kernel_jmp
        long destination
    gets more complicated and slow because the address has to be split in two parts to always have a condition false... maybe 2 ljmp routines one for lager addresses and one for shorter could be used...
    from this:
    kernel_jmp  rdlong  krnl_pc, krnl_pc
                      mov   krnl_temp, krnl_pc
                      and   krnl_pc, cnt_0003_FFFF
                      and   krnl_temp, cnt_FFC0_0000
                      shr    krnl_temp, #4
                      or     krnl_pc, krnl_temp
                      jmp   #kernel_fetch
    instead of
                      jmp   #kernel_fetch
    and for lcall and so on...
    Edit:
    Scratch part of what I said.
    Relative jumps could be used till +/- 2Megainstructions. Short jumps +/-128 instructions modifying the krnl_PC directly... and a couple more tricks. All will depend on how fast the XMM is and so on... well it may be doable just for the fun of it.
    Visit some of my articles at Propeller Wiki:
    MATH on the propeller propeller.wikispaces.com/MATH
    pPropQL: propeller.wikispaces.com/pPropQL
    pPropQL020: propeller.wikispaces.com/pPropQL020
    OMU for the pPropQL/020 propeller.wikispaces.com/OMU
    Post Edited (Ale) : 12/6/2009 2:28:55 PM GMT
    edited 2009-12-06 14:21
    Oh OK if it ain't in ain't. The "ELKS" name is a bit cheeky then.
    edited 2009-12-06 14:36
    Actually I was thinking maybe it would be easier to start from a really old Linux version. Go back to 1.something.
    Would that not be a lot smaller/simpler?
    Is it disqualified?
    edited 2009-12-06 15:15
    The PC I ran unix on in the 90's (before Windoze 95) had 16MB of memory. I know the emulation used 8MB of that. I dare say not a lot of memory was required because I had a huge memory for my emulation. Even back then, unix was typically run on the discarded Dos pcs.
    Did they come as a complete distribution then? I still have the 400MB SCSI drive, but no pc old enough to run it.
    edited 2009-12-06 16:15
    heater said...
    Is it disqualified?
    I think that's kinda drawing a pretty long bow. 2.6 has been current since 2004, let's not go back any further than that 'eh ?
    If I thought it was easy I'd not have put my own money on the line.
    edited 2009-12-06 21:21
    heater:
    The problem is to get gcc up and running. Porting Linux (uCLinux) is not that difficult after that. It will have to run under a XMM kernel so everything could be possible...
    edited 2009-12-06 21:26
    @Ale,
    I guess you've had a little quality time with GCC source by now. What are the chances?
    I've looked at this before and it's a little *deep* for me [noparse]:)[/noparse] Makes one yearn for simple things.
    edited 2009-12-06 22:03
    It is not easy but it is doable.
    we need: gas, ld, libbfd and gcc. It is not only gcc and it depends on binutils. I never ported gcc or binutils so I really do not know how much work it is. It may not be a bad idea to make a team to attack the problem. The code can be compiled with Bill's LAS or my own compiler till gcc produces something usable, meanwhile binutils can also be ported.
    edited 2009-12-06 22:22
    Ale : "The problem is to get gcc up and running."
    As I've said all along. And that problem is way out of my league.
    edited 2009-12-06 23:12
    @all,
    Sorry if this has been posted before, but I found a nice article on the C language "extensions" that GCC implements which are required to build Linux here.
    This makes it clear (in case Brad's posts were not clear enough) that you can't really expect to build Linux (at least as Brad has defined it) with anything other than GCC. Although some progress has apparently been made with "clang" (see here), I don't think this is a real alternative yet.
    As Ale, heater and others have already pointed out, this means that the first step in the process is to add a new target architecture to GCC so that it can act as a cross compiler.
    However, the "bare metal" architecture of the Prop is completely unsuitable for running Linux. A the very least, Linux will require an LMM kernel architecture. But an LMM kernel on the Prop can still only address 32Kb, so it really needs to be an XMM kernel - so the zeroth step is to identify, define or develop the XMM kernel you intend to use. Without knowing your target architecture, you can't begin any sensible work on the GCC code generator (which is the main bit you will have to write by hand from scratch).
    I muddled my way through this step-by-step on Catalina, which now has a multiplatform XMM kernel which is suitable (although by no means ideal) for use as the target of a C compiler. There may be other XMM kernels under development that are also suitable, but I'm not aware of any others actually being available or in use just yet. So if anyone is seriously intending to attempt this challenge, I would advise them to either use the Catalina XMM kernel, or at the very least take a have a look at it before designing your own (at least this way you'll know what you're in for before you start).
    Ross.
    P.S. A note on memory size: Based on experience with Catalina, when using LMM/XMM on the Prop you can pretty much expect to double or possibly even quadruple the memory size over and above what might expect on an Intel architecture. So if Linux takes 1Mb on Intel, expect it to take between 2 and 4 Mb on the Prop. If I were doing this challenge I would probably start with a platform that had at least 8Mb (to allow for what will undoubtedly be initially a sub-optimal code generator).
  • VIRANDVIRAND Posts: 656
    edited 2009-12-07 00:25
    I use small linuxes, and have seen ones on floppies, and have NO CLUE why they would be harder to fit in 64K than ZicogCP/M or PropDOS or QNX (a embedded? UNIX floppy demo that looked like Windows 95). I prefer the ones that are GUI *AND ALSO* fit on those tiny business card CDs that don't even need a hard drive in the machine to USE.
    Because I don't trust huge programs that apparently do next to nothing several billion times a second, having at one time or another written similar, even GUI, functions in a few lines of BASIC, nor those that can't be a whole app in one executable file.
    Puppy linux and KILL BILL and SLAX are some I can remember that fit on tiny business card CDs and did more than Windows WITHOUT EVEN PUTTING A HARD DRIVE IN THE MACHINE.
    edited 2009-12-07 01:03
    VIRAND,
    Those "business card" CDs can still contain about 65Mb.
    The average size of a 2.6 kernel is reportedly about 1.5Mb. There are reports of 2.6 kernel sizes down to about 600k (e.g. here) provided you remove various features such as USB support, SCSI support etc - but no Linux kernel size has ever been anywhere near 64k.
    Ross.
  • ericballericball Posts: 774
    edited 2009-12-07 01:09
    Not that I'm a Linux kernel hacker, but I think this would be a very limited architecture.· A single cog executing code from XMM with the remaining 7 cogs implementing (hub) memory mapped devices.· The XMM would also have to implement any MMU functionality, along with multitasking & device "interrupts".· (Although, thinking about it, that's more a "switch tasks/threads on block / check status on next slice", so not that bad.)
    Composite NTSC sprite driver: Forum
    NTSC & PAL driver templates: ObEx Forum
    OnePinTVText driver: ObEx Forum
    edited 2009-12-07 01:32
    @ericball,
    Limited, yes - and also slooooow - but fully functional. I'm assuming the purpose of doing this is simply to meet the challenge, since the ultimate usefulness of it is (to say the least) a bit questionable smile.gif
    Ross.
    edited 2009-12-07 02:26
    I would use two props. One just for SRAM and SD (e.g. RamBlade), the other for I/O, with high speed serial between them. The RamBlade can do 1-pin video and 1-pin Keyboard (at least with a 50c micro) instead, or serial, and stand-alone.
    I do not believe it's just to meet the challenge, as I think it could be really useful as a mini o/s. The ethernet module that was pointed out recently has a mini *nix running on it. I don't believe it will be sooo slooow on a prop. Remember, it used to run on slow intel processors amny moons ago. It is just that now people are after graphics. Ditch that and it's fine.
    edited 2009-12-07 02:46
    @Cluso,
    Yes, I'd kind of assumed it would only be feasible at all if you can use multiple Props.
    As to its eventual usability - well, I can see Linux on the Prop II being fast enough to be useful (maybe) - but considering the overheads of LMM and XMM I just don't think the Prop I has enough processing power or internal RAM.
    So much so that I'm tempted to offer a subsidiary challenge to Brad's - i.e. a free copy of Catalina if you can complete a "cd /" command (i.e. list the files in the root directory, which normally doesn't have much in it) typed into a bash shell within 10 minutes of doing a cold boot of Linux tongue.gif
    Ross.
    edited 2009-12-07 04:00
    Actually, provided only 1 serial port, or alternatively only a mono TV and keyboard are required, then a single prop (RamBlade) could do it.
    I am only after speeds equivalent to the old pcs, and functions of the old pcs. I am NOT after a full-blown *nix system, just a basic *nix o/s. I think that is where the confusion is setting in.
    The moment we get into multiplexing the address or data pins, extra instructions slow the sram access down dramatically. It will be far more evident in a native XMM environment than currently on the ZiCog interpreter. This is my opinion and others will disagree. Unfortunately, everything is a compromise.
    So my minimum hardware specifications would be
    • 512KB SRAM
    • SD (microSD preferred)
    • Eeprom (or equivalent) so the pcb can self boot to SD
    • 2 pins for serial or mono 1-pin TV and 1-pin PS2 keyboard (tiny micro to interface kbd allowed)
    • Any other expansion would be via another optional prop via the serial.
    • Note this uses all pins and NO LATCHES.
    Have I said before, it is not for the $, so I am not interested in the restrictions of what constitutes a valid *nix platform.
    Post Edited (Cluso99) : 12/7/2009 4:15:37 AM GMT
