watt sensor?
mctrivia
I need to measure both current and voltage for 20A 120V circuit.
I could use a 20A hall effect IC and a 64 to 1 voltage divider(150V RMS to 3.3Vpeak) and use 2 analog pins on the prop 2 to get my readings but what I was hoping for was a cool IC that could read both voltage and current with preferably a digital output so I could use the prop1 and not have to wait.
Anyone know of anything?
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
Watt?·
You're not asking for too much are you?
Without an output/signal to determine the phase relationship of·e and·i it wouldn't be much good.
Pretty much what Mr. Allen said.
I found an example that might explain in more detail...
http://www.ece.unh.edu/courses/ece401/Referernce/AC%20Analysis.pdf
On page 4 is a graph that represents the phase relationship in an AC circuit when driving a capacitive load.· So one guestion up front would be:· what type of load are you intending to have?
The AC current detected would be the result of the two instantaneous values of E and I at the time of measurement.· Maybe knowing ("assuming") that there would a 90 degree phase-shift between the two would help in the calculation.· But again, that all depends on what type of load is involved.· I would suspect that the phase shift varies under certain load types or conditions.
BTW - in capacitive load situations, the current leads the voltage by 90 degrees; with inductive, the voltage leads the current by 90 degrees.· There was a phrase that we used in school to help remember that, but it escapes me at the moment.· In purely resistive loads, there is no phase shift.
Later,
DJ
Instead of:
"Those who can, do.· Those who can't, teach." (Shaw)
I prefer:
"Those who know, do.· Those who understand, teach." (Aristotle)
A hall effect IC and voltage divider give sin waves out so you can compute both real and imaginary power usage. for my case though just taking the RMS value of each will give me a close enough estimate. I just woundered if there was an IC that could give me both the current and voltage.
"Close enough estimate"?· No way.· But, have fun.· Ever the lone voice crying in the wilderness, I just didn't want anybody to get the wrong idea.
Post Edit -- Residential users don't have capacitor huts, but·commercial users·do.· The power company would love it if we had to.· They calculate for lost revenue given certain models in determining rates, so that they aren't giving power away, but, oh!,·the current spikes.
Post Edited (PJ Allen) : 12/5/2009 5:28:04 PM GMT
@Mr. Allen - that's it! Thanks.
DJ
Instead of:
I prefer:
Phasors on stun.·
e·X i would not result power in any (AC) context other than light bulbs.· If it's about·fans, or refrigerators, or air conditioners, then you need to know the phase angle.
It's not because I say so.· I'm not cherry-picking data and burying nuggets·like cats in a sandbox, I·don't work for the University of East Anglia, NASA, or the UCLA History Dept.· It's the physics, the truth.·
Post Edit -- Added hot-link (not the La. variety)
http://en.wikipedia.org/wiki/Power_factor
http://en.wikipedia.org/wiki/AC_power#Real.2C_reactive.2C_and_apparent_power
Post Edited (PJ Allen) : 12/6/2009 1:35:17 PM GMT
1) I have a diploma in Electronics Enginering and understand phasors.
2) Accuracy is not of any importance. I really only need the current draw and the voltage to make sure things are working right.
3) Power is made up of real and imaginary power. multiplying the rms values of e and i will give you the real power you need to know the phase angle or instintatnius values to calculate imaginary.
4) Once the prop 2 is out I will have enough pins to compute both real and imaginary power.
was just woundering if there was an ic i could use for e and i or if i need to make my own circuit.
http://cgi.ebay.com/P3-KILL-A-WATT-LCD-ELECTRICITY-MONITOR-METER-P4400-NEW_W0QQitemZ200413874341QQ
Simple to use, compact·and ready to go. Gives volts, amps, VA, watts, time, hz, power factor, & cumulative·KWH. Lets you easily experience the "Prius Effect" on your home appliances.
It verified my suspicion that·my neighbor's·highly-touted and overpriced ($400) Edenpure quartz/copper electric heater wasn't·noticeably more efficient than a cheap·electric coil heater.
I will just have to layout the circuitry on my PCB. not a problem.
- Stephen
On the·second some hall effect current sensors from AllegroMicro
http://forums.parallax.com/showthread.php?p=857153
http://forums.parallax.com/showthread.php?p=856024
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
