Serial to Multiple BS2s via Programming Port?
Is it possible to command multiple Stamps via their programming ports from a PC's serial port using a daisy chained DB-9 cable? I only need to send data one way (PC-to-BS2s).
Ross
Ross
Ross
Jeff T.
So, basically use a Stamp as a line driver to pass on the serial data to the other Stamps' programming ports? Interesting, I might try that!
Thanks!
Ross
That does not rule out the programming ports·, it's a case of whats best with your setup / plan.
Jeff T.
Ross
There may be other solutions but I think the above·would work nicely, the MAX chips are very straightforward to use and relatively cheap.
Jeff T.·
Ross
