Recommendations for a cheap c-size (18"x24") scanner ? — Parallax Forums
BeanBean Posts: 8,129
edited 2009-12-05 19:06 in General Discussion
We have some c-size (18" x 24") cad drawings that we need to scan (black and white only).
But the scanners I have found that handle c-size are about $6,000 !!
Does anyone know of any cheaper options ?
The drawings are in sheets, so it can be a flatbed or a sheet feed scanner.
We would probably spend up to $2500 for one.
Bean
1st rule of finance...Don't lose money.
Never be ashamed of making an honest·profit.
Live within your means...Make do, or do without.
  • Tim-MTim-M Posts: 522
    edited 2009-12-04 16:18
    Hi Terry,
    Just so you know...
    When we need larger sheets scanned here at work (which isn't all that often) we head to our local blue print supplier. They are happy to scan large black and white formats and generate digital files at a rate of 85 cents per square foot of original. This assumes that you'd rather not own you own equipment or don't have a lot of volume to do.
    Tim
    Edit: Here is a link to the current price list from Bill's Blue Print - the shop we are using.
    http://www.billsblue.com/bbp/pricelist2008.pdf
    Post Edited (Tim-M) : 12/4/2009 4:36:36 PM GMT
  • John R.John R. Posts: 1,376
    edited 2009-12-04 19:33
    large format scanning hardware + cheap
    see also: Military Intelligence, Government Efficiency, Affordable Healthcare, Low Cost Beach Front Property, etc...
    Back in the days of pen plotters, there were a few devices that attached to the pen carriage and could scan large format, but I don't think they worked that well, and I haven't seen them in quite some time.
    Like Tim, I've always went to the blueprint house.
    John R.
    Click here to see my Nomad Build Log
    edited 2009-12-04 19:36
    The other option is to scan in sections with a smaller flatbed and "stitch" the images together. I have an HP 4670 that works great for this, but I don't think they are in production anymore.
    John R.
  • BeanBean Posts: 8,129
    edited 2009-12-05 03:31
    We can't use a service, and we have a few thousand drawings to scan, so the "stitch" method is out of the question.
    Thanks anyways.
    Bean.
    edited 2009-12-05 04:58
    Go to eBay and search wide format scanner. There are several possible candidates there.
    Is the problem with the service confidentiality agreements, or physical location? You may be able to work out either of those by making arrangements to "rent" the scanner, either at the service location, or possibly even be able to take the scanner to the location of the prints.
    Then again, at a few thousand drawings, compared to a service, the price of a scanner might be a bargain.
    Going through some math:
    17 x 22 = 374 Sq In
    18 * 24 = 432 Sq In
    Call it 400 Sq Inches
    Using a 12 Megapixel camera (eg a high end digital SLR):
    12M / 400 = 30k Dots Per Sql In yields about 170 DPI
    Not great resolution, but depending on the nature of the drawings, it should be enough, at least of the prints are in decent condition.
    You might be able to set up a camera to image the sheets. The secret would be getting the sheets to lay flat, and getting good, even lighting. For smaller sheets, I've used a piece of glass to keep them flat. If you light at an angle, glare is not a problem.
    John R.
