Advice on hot air rework station.
mctrivia
I realy need a hot air rework station for fixing surface mount boards and removing qfn and bga parts put on incorrectly. Anyone have advice on something good and as cheap as possible. Or maybe someone have one for sale or loan?
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
I'll poke around my contacts to see if anyone has a demo unit for sale or a loaner.
Andrew Williams
WBA Consulting
WBA-TH1M Sensirion SHT11 Module
Special Olympics Polar Bear Plunge, Mar 20, 2010
Haven't tried it...but it has lots of options!
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
Search for it, you will find it a useful post I think
"Where am I? Where am I going? Why am I in a handbasket?"
http://forums.parallax.com/forums/default.aspx?f=15&m=360823
Searider
store.sra-solder.com/product.php/6264/26
We do not use the vacuum at all, but the hot air parts works flawlessly. Have a huge number of tips for the station.
Not the best price for a hot air station, but a pretty good price for what you get.
James L
James L
Partner/Designer
Lil Brother SMT Assembly Services
Are you addicted to technology or Micro-controllers..... then checkout the forums at Savage Circuits. Learn to build your own Gizmos!
Alex Burke
"Beware of computer programmers that carry screwdrivers." -Leonard Brandwein
Leon
Amateur radio callsign: G1HSM
I've got a couple of good soldering stations already, including the Hakko my parents bought me while I was at school (a few years ago now), and even the iron on the 968 does a credible job.
If you always do what you always did, you always get what you always got.
http://www.circuitrework.com/features/628.shtml
Andrew Williams
WBA Consulting
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200357778023&ssPageName=ADME:X:RTQ:US:1123
Jim Fouch
FOUCH SOFTWARE
Can a· Hot-Air Rework station also work with Through-hole components or do you need both and de-solder and hot-air to work on both surface mount and Through-hole ?
Searider
Some people prefer using a hot air station to desolder. I prefer using my Hakko 808. It makes quick work of through-hole components.
I can salavge a motherboard of all its through-hole components in less than 5 minutes using it.
Jim Fouch
FOUCH SOFTWARE
thanks for your experience. I figured that a desoldering system was much faster at removing Through-hole components.
Searider
Seems like the really small stuff might 'blow away'.
I am thinking of soldering luxeon rebel stars in a matrix and was wondering if this is the way to do it 'at home'.
Post Edited (OakGraphics) : 12/19/2009 4:19:37 PM GMT
The parts are held in place by the solder paste. You need to keep the air flow down, of course, for smaller parts.
Leon
http://cgi.ebay.com/ws/eBayISAPI.dll?ViewItem&item=200357778023&ssPageName=STRK:MEWAX:IT
Product Description
SMT SMD Hot Air Desolder Rework Station /Model: AT-852D+, this product is as good as our other products ever before. Please kindly refer to the details as following:
Features
Temperature rapidly rise and adjust conveniently, temperature digital display.
The temperature is very accurate and reliable, will not affect by air blowing.
Perfect stand-by function, when the handle is placed on the handle shelf, now the system is on stand-by state, No matter in what location of wind establishes, will blown out breezy to makes the life longer. When get up handle will be on stand-by state.
Anti-static design, prevent static electricity or the electric leakage form PCB damage.
Untouched soldering mode, avoid components shifting and thermal shock.
The air flow and the temperature can be adjust greatly and it can solder or de-solder the QFP and SOP, PLCC, BGA type IC
Use the import heating element, the spray nozzle is in line with international standards
It uses the good-quality and high-speed motor to produce cyclostrophic wind, make the heat uniform distribution and has big dynamic range of the thermal power.
Blow cooling system automatically after shut down equipment, prolong the service life of machine.
Specifications
Power Consumption: 280W
Fan: Soft whirlwind
Capacity: 23L/min(Max)
Hot Air Temperature: 100°C~480°C
Outer Dimensions (W x H x D): 187×135×245mm
Weight: 4.5KG
Input
110V 60Hz or 220-240V 50Hz
All unit will be sent with input voltage adaptor comply with buyer's country's standard, unless buyer contact us with special request prior to payment made.
•Includes four nozzles (A1124, A1130, A1196, A1197)
•Hot air gun adjustable from 100-500°C (212-896°F)
•Iron temperature adjustable from 200-480°C (392-896°F)
•Independent control of flow rate, gun temperature, and iron temperature
•Independent power switches
•1 year manufacturer's warranty
•110VAC Standard Power - 450W (max)
•ESD Safe
•12 lbs. shipping weight
