Does anyone have code for interfacing with all the buttons on a sega 6 button? Accessing the abc and directional buttons is simple. However the xyz buttons use a different approach.
Here is the code, I stripped out everything but the code to test for buttons x,y, and z.
Attached is a description of the interface for 6 button sega controllers, in text format.
;-------------------------- DEVICE DIRECTIVES --------------------------
DEVICE SX28,OSC4MHZ,TURBO
IFDEF __SASM ;SASM Directives
DEVICE STACKX,OPTIONX
IRC_CAL IRC_SLOW
ELSE ;Parallax Assember Directives
DEVICE STACKX_OPTIONX
ENDIF
RESET Initialize
;---------------------------- DEBUG SETTINGS ---------------------------
FREQ 4_000_000
;------------------------ INITIALIZATION ROUTINE -----------------------
Initialize
;Port Direction Configuration at 4mhz each clock is 4.25u sec
Timer = $10
GenXYZ EQU 24
Joystick_Mid equ $0E ;XXX,XXX,XXX,XXX,XXX,X,Y,Z
Joystick_Low equ $0D ;XXX,C Button,XXX,B Button,Right,Left,Down,Up
Joystick_High equ $0F ;XXX,XXX,XXX,A Button,B Button, X Button, Y Button, Z Button
Joystick_M_wip equ $1E
Joystick_L_wip equ $1D
Joystick_H_wip equ $1F
mov W,#$1F ;Allow Direction configuration
mov M,W
mov !rb,#%11111111 ;Set port B bits 0-7 to input
mov !ra,#%00000000 ;Set port A bits 0-7 output bit 0 is select
mov !rc,#%00000000 ;Set port C bits 0-7 output
clrb ra.0 ;turn select off
Pause MACRO
mov Timer, #18 ;1 cycle
:Loop
decsz Timer ;2 cycles or 4 cycles
jmp :Loop ;3 cycles
ENDM
bp0
pause
setb ra.0 ;turn select off, setting voltage to 5
pause
clrb ra.0 ;turn select on, setting voltage to 0
nop
nop
nop
nop
nop
;------------------- should be select on data now
mov w, rb
mov Joystick_Mid, w
jnb rb.0, light ;check first bit, which should be button z
jmp nolight
light: clrb rc.6 ;turn off led
jmp bp0
nolight: setb rc.6 ;turn on led
nop
nop
jmp bp0
;---------------------------- MAIN PROGRAM -----------------------------
Main
jmp bp0
I got that one and a couple of others. Actually I attached the text version of that document with my code in my previous post. The document seems to call it pulse 3, but it seems to be on the 4th pulse when you should look for XYZ. The last pulse held high I believe, while you read the buttons. I have the code set to light up, when I get a z, however it actually lights when I get an up. Looking at the pdf again, I added another toggle of the select line, and left it high, however it did not seem to make a difference. I changed the code to display the LED when the A button is held, and then also for the B button, which shows me I'm controlling the select properly. I'm running with the internal clock set to 4MHz. It seems it must be my timing that is off,below is the code I'm trying to use now.
bp0
pause ;93
pause ;93
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
nop ;1
; mov w, rb
; mov Joystick_Mid, w
jmp nolight
jmp bp0
jmp bp0
OK finally got it working. There were two problems. The first is that I needed to wait at least 20,000 cycles between reads of the xyz buttons. I was trying to read them too quickly, and results were getting reset. It appears about 200 Hz is the fastest rate to sample the xyz buttons. Secondly, the documentation I found was incorrect in some places. Pulse 3, meant read XYZ on the third pulse, however there are two different timing diagrams in the document one shows read on third pulse, and the other showed read on fourth pulse. Below is the working code, in case anyone is interested.
; reads the all genesis buttons, and will turn a light on if x and z are pressed
IRC_CAL IRC_SLOW
ENDIF
RESET Initialize
FREQ 4_000_000
Initialize
Timer = $10
GenXYZ EQU 24
mov M,W
;------------------------ Start Pause
Pause MACRO
mov Timer, #10 ;1 cycle
:Loop
jmp :Loop ;3 cycles
ENDM
;------------------------ End Pause
;------------------------ Start LongPause
LongPause MACRO
mov Timer, #254 ;1 cycle
:Loop
jmp :Loop ;3 cycles
ENDM
;------------------------ End LongPause
;------------------------ Start ReadJoystick
ReadJoystick MACRO
nop ;1
pause ;~52
nop ;1
pause ;~52
nop ;1
pause ;~52
nop ;1
pause ;~52
nop ;1
pause ;~52
;------------------- XYZ data is now available
mov w, rb
mov Joystick_Mid, w
ENDM
;------------------------End ReadJoystick
bp0 ;Main Joystick Read
ReadJoystick
jmp nolight
jnb rb.2, light2
jmp nolight
light2:
jmp dostuff
dostuff: ;need to wait at least 20,000 cycles at 4Mhz before you attempt to read controller again 200 controller reads per sec max
longpause ;~2400
longpause ;~2400
longpause ;~2400
longpause ;~2400
longpause ;~2400
longpause ;~2400
longpause ;~2400
longpause ;~2400
jmp bp0
Main
jmp bp0
I did a Google search using the following terms...
sega 6 button controller interface
...and found this:
www.ecgf.uakron.edu/grover/web/ee263/labs/Parts/Sega%20Six%20Button%20Controller%20Hardware%20Info.pdf
It's a PDF file 1996 called "Sega Six-Button Controller Hardware Info."
It explains how to read not only the ABC buttons, but also the XYZ.
I know absolutely nothing about this controller and found this information in under a minute using Google.
PeterM
