measuring speed with x band motion detector
Hi, i've just bought the x-band motion detector and am waiting for it to arrive. I was hoping to fit some form of directional antenna to it and measure the velocity of people or similar. I understand how to interface it with a microcontroller and measure the doppler shift but was wondering if anyone knew what type of antenna/horn i should fit for an increased range? Any help would be appreciated, thanks.
<FONT>Steve
What's the best thing to do in a lightning storm? "take a one iron out the bag and hold it straight up above your head, even God cant hit a one iron!"
Lee Travino after the second time being hit by lightning!
The range can be increased with a simple horn antenna. But the module has patch antennas, so the geometry prevents one from doing a proper and technically correct antenna. You also create other technical issues by adding any sort of 'antenna'.
You can't feed it with a waveguide as the patch antennas are physically larger than 10 GHz waveguide. You might be able to build twin dipoles (one for rx and the other for receive), but you will need to provide some isolation between them. Having dipole antennas makes feeding any sort of dish or horn antenna much more technically correct. But there are many other problems that might surface with the addition of mods.
