getting the HM55B compass module to work
I have use a·BS to get data from other BS2s and use that BS2 to send·all the infomation·to my computer. relay1, relay2 and LED are the data i get from the other BS2s. However, I want to do a compass module in the BS itself so that I can send readings from the compass to my computer. However, without inserting the compass code, my vb program are able to display information from relay1, relay2 and LED. When I inserted the compass code, all readings are empty. I have try without using my vb program and uses the·debug command to check. It's the same too. How can I make my compass and the other readings work too ?
The code with the compass code
The code without the compass code
' {$STAMP BS2} ' {$PBASIC 2.5} relay1 PIN 0 relay2 PIN 1 LED PIN 2 DinDout PIN 6 ' P6 transceives to/from Din/Dout Clk PIN 5 ' P5 sends pulses to HM55B's Clk En PIN 4 ' P4 controls HM55B's /EN(ABLE) Reset CON %0000 ' Reset command for HM55B Measure CON %1000 ' Start measurement command Report CON %1100 ' Get status/axis values command Ready CON %1100 ' 11 -> Done, 00 -> no errors NegMask CON %1111100000000000 ' For 11-bit negative to 16-bits x VAR Word ' x-axis data y VAR Word ' y-axis data status VAR Nib ' Status flags angle VAR Word ' Store angle measurement reading1 VAR Word reading2 VAR Word reading3 VAR Word DO IF relay1 = 1 THEN reading1 = 1 ELSE reading1 = 0 ENDIF IF relay2 = 1 THEN reading2 = 1 ELSE reading2 = 0 ENDIF IF LED = 1 THEN IF LED = 1 THEN ' Motion Detected reading3 = reading3 + 1 ' Update Trip Counter DO : LOOP UNTIL LED = 0 ' Wait For PIR To Clear ENDIF ENDIF 'DEBUG HOME, "relay1"," = ", DEC1 reading1 'DEBUG CR, "relay2", " = ", DEC1 reading2 PAUSE 100 SEROUT 16,16468,[noparse][[/noparse]DEC1 reading1,DEC1 reading2,DEC1 reading3,DEC3 angle] SEROUT 16,16468,[noparse][[/noparse]LF] 'DEBUG HOME, DEC1 reading1 'DEBUG CR, DEC1 reading2 'DEBUG CR, DEC1 reading3 'DEBUG CR, DEC angle GOSUB Compass_Get_Axes ' Get x, and y values angle = x ATN -y ' Convert x and y to brads angle = angle */ 360 ' Convert brads to degrees 'SEROUT 16,16468,[noparse][[/noparse]DEC3 angle] 'SEROUT 16,16468,[noparse][[/noparse]LF] 'DEBUG HOME, "x-axis N(-S) = ",SDEC x, ' Display axes and degrees 'CLREOL, CR, "y-axis W(-E) = ", 'SDEC y, CLREOL, CR, CR, "angle = ", 'DEC angle, " degrees", CLREOL PAUSE 150 ' Debug delay for slower PCs LOOP ' -----[noparse][[/noparse] Subroutines ]-------------------------------------------------------- Compass_Get_Axes: ' Compass module subroutine HIGH En: LOW En ' Send reset command to HM55B SHIFTOUT DinDout,clk,MSBFIRST,[noparse][[/noparse]Reset\4] HIGH En: LOW En ' HM55B start measurement command SHIFTOUT DinDout,clk,MSBFIRST,[noparse][[/noparse]Measure\4] status = 0 ' Clear previous status flags DO ' Status flag checking loop HIGH En: LOW En ' Measurement status command SHIFTOUT DinDout,clk,MSBFIRST,[noparse][[/noparse]Report\4] SHIFTIN DinDout,clk,MSBPOST,[noparse][[/noparse]Status\4] ' Get Status LOOP UNTIL status = Ready ' Exit loop when status is ready SHIFTIN DinDout,clk,MSBPOST,[noparse][[/noparse]x\11,y\11] ' Get x & y axis values HIGH En ' Disable module IF (y.BIT10 = 1) THEN y = y | NegMask ' Store 11-bits as signed word IF (x.BIT10 = 1) THEN x = x | NegMask ' Repeat for other axis RETURN END
' {$STAMP BS2} ' {$PBASIC 2.5} relay1 PIN 0 relay2 PIN 1 LED PIN 2 reading1 VAR Word reading2 VAR Word reading3 VAR Word DO IF relay1 = 1 THEN reading1 = 1 ELSE reading1 = 0 ENDIF IF relay2 = 1 THEN reading2 = 1 ELSE reading2 = 0 ENDIF IF LED = 1 THEN IF LED = 1 THEN ' Motion Detected reading3 = reading3 + 1 ' Update Trip Counter DO : LOOP UNTIL LED = 0 ' Wait For PIR To Clear ENDIF ENDIF PAUSE 100 SEROUT 16,16468,[noparse][[/noparse]DEC1 reading1,DEC1 reading2,DEC1 reading3] SEROUT 16,16468,[noparse][[/noparse]LF] 'DEBUG HOME, DEC1 reading1 'DEBUG CR, DEC1 reading2 'DEBUG CR, DEC1 reading3 LOOP END
Remember that your SEROUT statements in your program come before the GOSUB and the angle calculations, so the first angle sent to the PC will be garbage (probably zero).
