Fast Datalogging: USB, SD, other?
FlyingFishFinger
Hi-
We'd like to design a CAN datalogger for our solar car. Since the maximum data rate on CAN is 1MBit / second, we want to design for this.
Since race days can literally last all day (10-12 hrs) without a long enough break for downloading data, we need to record the full day. Assuming we use an 8GB media, that gives us about 17 hours, which is nice. With this in mind, should we use a USB or SD card solution? Seems to me SD interfaces can't handle SDHC very well yet, but USB is a little more expensive...
Rafael
UC Berkeley '12 EECS
CalSol: Berkeley Solar Car team
www.calsol.berkeley.edu
Rafael
Can the data be compressed? What's the worst case data rate (not the raw limit for CAN)?
Compression, no. We want the raw CAN ID's and messages (ID's may be mapped to device names, but that's about it) in plain text files.
Rafael
there are many ways to compress:
*If you are likely to get lots of sequential values then setting a symbol as repeat followed by a number of times will give good compression
*If you have a set number of symbols and some are used more often then others the hufman compression is a good way to go.
*Use numbers to refer to names
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
it is only possible to send 8 bytes in a single packet period !!
to send more than 8 bytes, it is necessary to break the data into 8 byte packets, then re-assemble at the other end, which of course takes time.
so with the 11 bit identifier frame, you are sending 50 bits of "wrapping" with every 64 bits (8x8) bits of data.
using a 29bit identifier frame makes that worse of course.
thus, in an ideal world, the maximum data transfer rate would be 500Kbits/second.
I would probably divide that by say 4 ( a complete guess) giving 125Kbits of data per second.
that would give 15KBYTES/second.
below is quite a good thread on the subject
http://www.electronics-related.com/usenet/design/show/20604-1.php
I am probably being conservative, but illustrating the main point that 1Mb/s CAN will only give tens of kilobytes per second.
http://instruct1.cit.cornell.edu/Courses/ee476/FinalProjects/s2008/dhp22_spg32/dhp22_spg32/index.html
We don't know for sure what and how many messages we'll be sending yet, as that's a software implementation at least 6 months away. We'd like to build the hardware such that it's adaptable to whatever throughput we end up using. I'll consult with our electrical lead, but the logger project you mentioned should be very helpful[noparse]:)[/noparse]
Thanks!
Rafael
KJ6AWU
