Tv terminal TEST....
i have propeller profesional dev board...i want to test TV TERMINAL (see attacment)....the problem is i dont know how to connect from propeller pin to tv terminal·on board because it is have 4 terminal (VA(560ohm),V0(1.1kohm),V1(560ohm),V2(270ohm).pls help me....
Post Edited (pusink) : 12/2/2009 6:03:45 AM GMT
As far as I remember the TV_Terminal (without _Demo) contains a schematic on how to connect the prop-pins with the 4 resistors needed for the TV out. But you could also have a look in the Education Lab PDF. I think there's a schematic of the demo board which also runs TV driver from port bit 12 on.
