Prop memory talk?
Zap-o
I am wondering why the propeller uses only one pull resistor with the memory IC. I2C uses 2 pullups and so if I want to use another device my propeller wont work unless I use other Pins.
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
Are you sure. I think that I tried this and it would not program to eeprom. Hum - I will try it again.
A 10k pull up on the clock will make no difference to the props ability to drive the line so it should not have affected the eeprom operation.
Graham
However, the boot code of the prop makes the SCL line an output so the pullup is not required.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
