LED blinking??
I have made a "automatic night light" for class basically i am using a ds1302 , crystal and a photo resistor. also using the .01 capacitor and appropriate wires
this is what it does.
automatically turns on the led if the time is more than 45 seconds(46-59) if it less than 45 seconds it will turn on the LED if dark only.
i am having trouble when it is less than 45 seconds it will cause the LED to blink very fast instead of a solid on when it is dark.
here is my program i hope someone can help
' {$STAMP BS2}
' {$PBASIC 2.5}
[noparse][[/noparse] I/O Definitions ]
DataIO PIN 0 ' DS1302.6
Clock PIN 1 ' DS1302.7
CS1302 PIN 2 ' DS1302.5
LED PIN 15
[noparse][[/noparse] Constants ]
WrSecs CON $80 ' Write Seconds
RdSecs CON $81 ' Read Seconds
WrMins CON $82 ' Write Minutes
RdMins CON $83 ' Read Minutes
WrHrs CON $84 ' Write Hours
RdHrs CON $85 ' Read Hours
CWPr CON $8E ' Write Protect Register
WPr1 CON $80 ' Set Write Protect
WPr0 CON $00 ' Clear Write Protect
WrBurst CON $BE ' Write Burst Of Data
RdBurst CON $BF ' Read Burst Of Data
WrRam CON $C0 ' Write RAM Data
RdRam CON $C1 ' Read RAM Data
Hr24 CON 0 ' 24 Hour Mode
Hr12 CON 1 ' 12 Hour Mode
Dark CON 150
[noparse][[/noparse] Variables ]
index VAR Byte ' Loop Counter
reg VAR Byte ' Read/Write Address
ioByte VAR Byte ' Data To/From DS1302
secs VAR Byte ' Seconds
secs01 VAR secs.LOWNIB
secs10 VAR secs.HIGHNIB
mins VAR Byte ' Minutes
mins01 VAR mins.LOWNIB
mins10 VAR mins.HIGHNIB
hrs VAR Byte ' Hours
hrs01 VAR hrs.LOWNIB
hrs10 VAR hrs.HIGHNIB
date VAR Byte
month VAR Byte
day VAR Nib ' Day
year VAR Byte ' Year
ampm VAR hrs.BIT5 ' AM/PM Flag Bit
clockMode VAR hrs.BIT7 ' 12/24 Hour Mode Bit
ampmFlag VAR Bit ' 0 = AM, 1 = PM
modeFlag VAR Bit ' 0 = 24, 1 = 12 (Hours)
work VAR Byte ' Work Data
time VAR Word
[noparse][[/noparse] EEPROM Data ]
Sun DATA "SUN", 0 ' Day Abbreviations
Mon DATA "MON", 0
Tue DATA "TUE", 0 ' These data statements could
Wed DATA "WED", 0 ' contain the full day name and
Thu DATA "THU", 0 ' the code would still work
Fri DATA "FRI", 0 ' without change.
Sat DATA "SAT", 0
[noparse][[/noparse] Initialization ]
Init:
reg = CWPr ' Initialize DS1302
ioByte = WPr0 ' Clear Write Protect
GOSUB RTC_Out ' Send Command
[noparse][[/noparse] Program Code ]
Start:
GOSUB Get_Time ' Get The Current Date/Time
GOSUB Show_Time ' Display It
DEBUG HOME, secs
IF secs > $45 THEN
HIGH LED
ELSE
LOW LED
ENDIF
GOSUB Get_light
[noparse][[/noparse] Subroutines ]
Get_light:
HIGH 7 ' Read photoresistor with RCTIME
RCTIME 7, 1, time
DEBUG HOME, "time = ", DEC4 time ' Print value to Debug Terminal
IF (time > Dark ) THEN ' Compare reading to known dark value
HIGH 15
ELSE
LOW 15
ENDIF
GOTO Start
Show_Time:
' This routine uses DEBUG to display the Date/Time information but you
' would customize the routine to display the data you want on the device
' you want. Not all information needs to be displayed.
LOOKUP (day - 1), [noparse][[/noparse]Sun, Mon, Tue, Wed, Thu, Fri, Sat], work
DO ' Display Day Abbreviation
READ work, ioByte ' Read Each Character Into ioByte
IF (ioByte = 0) THEN EXIT ' If 0 then done
DEBUG ioByte ' Send Character To DEBUG Screen
work = work + 1 ' Increment Address
LOOP ' Next Character, If 0 Then Done
modeFlag = clockMode ' Save 12/24 Hour Clock Mode
clockMode = 0 ' Clear BIT7
ampmFlag = ampm ' Save AM/PM Flag
IF modeFlag = 1 THEN ampm = 0 ' Clear BIT5 (12 Hour Mode only!)
DEBUG " ", HEX2 month, "/", HEX2 date, "/", HEX2 year, " "
IF (modeFlag = Hr24) THEN ' Check For 24 Hour Display mode
DEBUG HEX2 hrs, ":", HEX2 mins, ":", HEX2 secs
ELSE
DEBUG HEX2 hrs, ":", HEX2 mins ' Print Hours/Minutes
IF ampmFlag = 0 THEN
DEBUG "AM"
ELSE
DEBUG "PM"
ENDIF
DEBUG " [noparse][[/noparse]", HEX2 secs, "]"
ENDIF
RETURN
RTC_Out:
HIGH CS1302 ' Select DS1302
SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]reg, ioByte]
LOW CS1302 ' Deselect DS1302
RETURN
Get_Time: ' DS1302 Burst Read
SHIFTOUT DataIO, Clock, LSBFIRST, [noparse][[/noparse]RdBurst]
SHIFTIN DataIO, Clock, LSBPRE, [noparse][[/noparse]secs, mins, hrs, date, month, day, year]
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
LED PIN 15
Dark CON 150
date VAR Byte
month VAR Byte
day VAR Nib ' Day
time VAR Word
Mon DATA "MON", 0
Sat DATA "SAT", 0
Init:
Start:
DEBUG HOME, secs
IF secs > $45 THEN
HIGH LED
ELSE
LOW LED
ENDIF
GOSUB Get_light
Get_light:
RCTIME 7, 1, time
HIGH 15
ELSE
LOW 15
ENDIF
GOTO Start
Show_Time:
ELSE
DEBUG "AM"
ELSE
DEBUG "PM"
ENDIF
ENDIF
RETURN
RTC_Out:
RETURN
RETURN
- Stephen
i am using a .01 microfarad capacitor.....
' {$STAMP BS2}
' {$PBASIC 2.5}
LED PIN 15
Dark CON 150
date VAR Byte
month VAR Byte
day VAR Nib ' Day
time VAR Word
Mon DATA "MON", 0
Sat DATA "SAT", 0
Init:
Start:
DO
GOSUB Get_light
IF secs > $45 THEN
HIGH LED
ELSE
LOW LED
ENDIF
LOOP
Get_light:
RCTIME 7, 1, time
IF secs < $46 AND time > Dark THEN ' Compare reading to known dark value
HIGH LED
ELSE
LOW LED
ENDIF
RETURN
Show_Time:
ELSE
DEBUG "AM"
ELSE
DEBUG "PM"
ENDIF
ENDIF
RETURN
RTC_Out:
RETURN
RETURN
' {$STAMP BS2}
' {$PBASIC 2.5}
LED PIN 15
Dark CON 190
time VAR Word
DO
PAUSE 100
RCTIME 7, 1, time
DEBUG HOME, "time = ", DEC5 time ' Print value to Debug Terminal
IF (time > Dark) THEN ' Compare reading to known dark value
HIGH LED
ELSE
LOW LED
ENDIF
LOOP
i had 2 many high LED commands !!! i simply fixed this with a goto command instead of high LED
and my goto was to the high LED!!!!
yay!!!!
