Access Bytes of Long Array — Parallax Forums
JCeeJCee Posts: 36
edited 2009-12-01 09:57 in Propeller 1
I am trying declare bytes of long arrays and I cant get it to work
Var
·Long Point[noparse][[/noparse]10]
·Point[noparse][[/noparse]0].byte[noparse][[/noparse]0]:= 10
·Point[noparse][[/noparse]0].byte[noparse][[/noparse]1]:= 20
·Point[noparse][[/noparse]0].byte[noparse][[/noparse]2]:= 30
·Point[noparse][[/noparse]1].byte[noparse][[/noparse]0]:= 10
·Point[noparse][[/noparse]1].byte[noparse][[/noparse]1]:= 20
·Point[noparse][[/noparse]1].byte[noparse][[/noparse]2]:= 30
I would like to be able to loop thru an array of points and set values of specific bytes.
Do·I have a syntax problem or is there a better way to do it. ·
    edited 2009-11-30 21:30
    What you're doing should work. What behavior do you observe that's unexpected?
    edited 2009-11-30 21:33
    The problem is that you can't use subscripts on both parts of the variable descriptor. You can't say "Point[noparse][[/noparse]x].byte[noparse][[/noparse]y]". What you can do is "Point.byte[noparse][[/noparse]x*4+y]".
    edited 2009-11-30 22:02
    My bad! Mike is right. I was so lulled by the innate naturalness of Point[noparse][[/noparse]*1].byte[noparse][[/noparse]*2] := 30 (odd that it's not allowed) that I didn't question it. You can also do:
    [b]byte[/b][noparse][[/noparse]*@Point[noparse][[/noparse]*1]][noparse][[/noparse]*2] := 30
    if you don't want to do the address calculation explicitly.
  • JCeeJCee Posts: 36
    edited 2009-12-01 03:21
    the loops run as expected
    If you use DAT, you can just do this...
    DAT
     Point0      BYTE     10, 20, 30
     Point1      BYTE     10, 20, 30
    Propeller manual page 99.
