2pe Motherboard with accelerometer and LED display communication
Could anyone help me communicate between the accelerometer and an LED 7 segment display using the 2pe motherboard.
The code I have tried is as follows, but it doesn't seem to be reading anything.
' {$STAMP BS2pe}
' {$PBASIC 2.5}
OWOUT 6, 0, [noparse][[/noparse]8]
Are there any recommendations for a different code.
Thank you,
Laura
' {$STAMP BS2pe}
' {$PBASIC 2.5}
Thank you,
Laura
You're really talking about two separate problems here, and you need to find out which one is causing you trouble. Try to read the accelerometer and display the values in a debug window (using DEBUG). If you don't have that working, there's no point in trying to display them on the LED. Once you've got that working, figure out how to display numbers on the LED.
Did you remember to load the 7SEG display driver into the AVR coprocessor first? Also, displaying numbers on the LED is similar to the way it's done in DEBUG: you have to precede the number with DEC. The documentation downloadable from the 7SEG-DB product page explains all this and more.
