MEMSIC 2125 sensor to use for an airbag
Hello !
I am looking for some code to get only accelaration from the MEMSIC 2125 sensor..
That means, no mather if my object is even or tilted, just need to know the acceleration if it´s pushed to start an action just like an airbag in a car might work.
Thank you all for your help.
Tom
Tom
thank you very much for your reply.
As far as i got it, i need dynamic acceleration.
I wanted to know, if this is possible with the MEMSIC 2125 sensor and my BS2, just as i guess an airbag works,to measure dynamic acceleration apart from tilt.
What are your experiences ?
- Stephen
You are perfectly right, but in fact: i am not going to install this in my car, so the Parallax MEMSIC 2125 looks like it will do this job.
I was just wandering, if anybody knows some code in combination with a BS2 to handle this.
Till now i could only find some examples, dealing with tilt.
Thanks for your help.
Thomas
If the tilt varies then it has to be measured and the acceleration due to the tilt calculated or looked up and subtracted out.
