Frequency meter for prop
Cenlasoft
I have been playing with coils and LC circuits with the prop. I need a simple (discrete parts ?555 timer) frequency meter to measure frequencies between 30hz and 1 khz. I have looked on the web, but have not found anything. I would appreciate any samples or suggestions. I am working with low frequencies on metal objects. My instrument is based on the Prop. I just need a meter to sense low frequencies using an LC circuit to monitor AC. I was thinking of using a tunable parallel LC circuit and 555 timer, but I am stuck.
Curtis
Curtis
Leon
Amateur radio callsign: G1HSM
Do you have access to a multimeter? many of them have a freq option.
Or:
The counter makes use of 5 cascaded CD40110 which combine a decade counter, a display latch and a 7 segment LED driver in a single chip. (The decimal points are driven by IC8x.) The counter allows up and down counting (although only up counting is used in the frequency counter) and counts on the rising edge. An over- and underflow indicator is provided via CD4044 which is fed back to the logic board to allow automatic adaption of the divider or gate time if the counter has an overflow.
www.triplespark.net/elec/analysis/FreqCnt/counter.html
Post Edited (Bob Lawrence (VE1RLL)) : 11/30/2009 3:33:26 AM GMT
Scratch that. Obsolete
Post Edited (kwinn) : 11/30/2009 3:57:55 AM GMT
If you want a discrete solution try the mc14553 3 digit BCD counter. Needs a few extra parts to work.
obex.parallax.com/objects/479/
Use the Propeller Serial Terminal or a serial LCD to read-out the frequency.
Rgds, David
