Problems with DS1302
I'm having issues with a DS1302 I have wired to a Propeller chip - usually when I hook up to the board with a prop clip, the clock appears to be lagging behind a few minutes (in one case several hours). Yesterday, it was about 20 minutes ahead!
I've also seen the clock stop ticking. I'm using DS1302_full, like this:
I did make a small change to DS1302_full, to turn off the tickle charging of the 3.2v battery attached
{ The DS1302 Real Time Clock }
RTC_CLOCK = 5
RTC_IO = 6
RTC_ENABLE = 7
{ Start the RTC }
rtc.init( RTC_CLOCK, RTC_IO, RTC_ENABLE )
rtc.config
PUB config ''Config DS1302. Call once after DS1302 power-up. ''Usage: rtc.config write(command(clock,ctrl,w),0) 'clear write-protect bit write(command(clock,sec,w),0) 'clear clock halt bit (MSB of seconds register) write(command(clock,sec,w),0) 'set 24h mode 'Trickle charger setup - OFF write(command(clock,tc,w),0) 'Examples of other useful config and control commands 'write(command(clock,sec,w),%1000_0000) 'set clock halt bit 'write(command(clock,ctrl,w),%1000_0000) 'set write-protect bit 'write(command(clock,sec,w),read(command(clock,sec,r))&%1000_0000) 'set 24h mode bit without resetting the other 7 bits
You might try disconnecting the 3.2V battery and seeing if that makes the problem go away (presuming you're using it as the backup, not as the primary power source).
