Bug in Spin compiler — Parallax Forums
MagIO2MagIO2 Posts: 2,243
edited 2009-11-30 14:24 in Propeller 1
Maybe it's already reported, but it's worth to be mentioned again and again for all the newbies:
The datatype of a label is not set to the datatype that comes after the label, but to the one before the label. As the label itself points to the data after the label, I'd consider this as being a BUG.
Example:
dat
  word $0000
initSeq
  word $000c, $0005, $0005, $0005, $0002, $0001, $0028, $0000
initData
  word $0000, $0100
  word $0100, $0000
  word $0200, $0107
  word $0300, $20C0
  word $0400, $0000
  word $0800, $0702
  word $0900, $0000
  word $0a00, $0000
  word $0c00, $0000
  word $0d00, $0000
  word $0f00, $0000
  word $0700, $0101
  word $1000, $B010
  word $1100, $0700
  word $0700, $0100
  word $1200, $3B01
  word $1300, $000B
  word $2900, $1200
  word $2A00, $9500
  word $3000, $0a00
  word $3100, $2613
  word $3200, $290A
  word $3300, $0A29
  word $3400, $1326
  word $3500, $0A0A
  word $3600, $031E
  word $3700, $1E03
  word $3800, $0607
  word $3900, $0303
  word $3A00, $040E
  word $3B00, $010E
  word $3C00, $0E01
  word $3D00, $0E04
  word $3E00, $0303
  word $3F00, $0706
  word $5000, $0000
  word $5100, $EF00
  word $5200, $0000
  word $5300, $3F01
  word $6000, $0027
  word $6100, $0300
  word $6A00, $0000
  word $8000, $0000
  word $8100, $0000
  word $8200, $0000
  word $8300, $0000
  word $8400, $0000
  word $8500, $0000
  word $9000, $1300
  word $9200, $0000
  word $9300, $0301
  word $9500, $1001
  word $9700, $0000
  word $9800, $0000
  word $f000, $0854
  word $f300, $1000
  word $f400, $1100
  word $f000, $0000
  word $0700, $7301
pub Init | ptr1, ptr2, cont
  ptr1:=0
  ptr2:=0
  cont:=1
  repeat while cont==1
    tv.str( string("SeqNum: ") )
    tv.dec( initSeq[noparse][[/noparse] ptr1 ] )
    tv.out( $0d )
    repeat initSeq[noparse][[/noparse] ptr1 ]
      tv.str( string( "CMD: " ))
      tv.hex( initData[noparse][[/noparse] ptr2 ], 4)
      ' cmd( initData[noparse][[/noparse] ptr2++ ] )
      tv.str( string( "  DATA: "))
      tv.out( $0d )
      ' data( initData[noparse][[/noparse] ptr2++ ] )
    ptr1++
    if initSeq[noparse][[/noparse] ptr1 ] == 0
      tv.str( string("End",$0d ))
      cont:=0
    else
      tv.str( string("SeqWait: ") )
      tv.out( $0d )
      tv.str( string( "Waiting",$0d ))
      waitcnt(clkfreq/initSeq[noparse][[/noparse] ptr1 ] + cnt)
    ptr1++
This currently works fine and as I'd expect it to work. But only because the workaround is already in place:
Remove the first word of the dat section and it will no longer do what's expected.
Reason:
Default type of a dat section seems to be byte. Now all accesses to initSeq are treated like a byte-array access.
Post Edited (MagIO2) : 11/29/2009 7:22:12 PM GMT
  • BradCBradC Posts: 2,601
    edited 2009-11-30 01:29
    You can also use just an alignment declaration, so there is no need to waste a word
      word
    fred
      word $0
    fred word
     word $0
    If the declaration is on the same line as the symbol, it's all good. If not then the symbol gets the last alignment (which defaults to byte in a DAT section)
    If you always do what you always did, you always get what you always got.
  • RaymanRayman Posts: 16,460
    edited 2009-11-30 13:54
    I wouldn't really call that a bug... If you don't specify the alignment of your label, the compiler is free to do as it wants...
    If you want to specify the alignment, just do like BradC suggests, and put it on the same line, right beside your label...
  • MagIO2MagIO2 Posts: 2,243
    I still call it a bug.
    With a label you reference the data comeing after the label, so the type should match that datatype of exactly this data and not the datatype that was valid before the label. But as I learned it is a minor bug with an easy workaround. But you have to be aware that it exists.
    I had to add debug-code to my module to find it because I was not aware of the problem - which cost some minutes. I guess some newbies will have a big headache when running in such a bug ;o)
