Using PHSA as WRLONG address — Parallax Forums
Andrey DemenevAndrey Demenev Posts: 428
edited 2009-11-30 03:39 in Propeller 1
Is it possible to use PHSA as WRLONG address? Like this:
WRLONG data, PHSA
The intention is to use PHSA as address pointer and avoid incrementing it in software to save some instructions
    edited 2009-11-29 09:35
    Andrey Demenev said...
    Yes, but why don't you try and find out?
  • Andrey DemenevAndrey Demenev Posts: 428
    edited 2009-11-29 09:42
    Thanks a lot!
    Just had an idea, but no Propeller at hand within few next days
    edited 2009-11-29 09:55
    Thanks a lot!
    Fair enough. Have a look at my HX512 DMA driver, I use something like this in there.
    edited 2009-11-29 17:59
    If you remember that wrlong simply ignores the two lsbs of the hub address, it relieves you of having to make sure they're zero in phsa when the source operand of the wrlong is fetched. 'Makes the setup timing a little less fussy. But don't forget that a chain of wrlongs in sequence do not get written every four counts of phsa. Each has to wait its turn with the hub timing. This could complicate things.
    Post Edited (Phil Pilgrim (PhiPi)) : 11/29/2009 6:05:40 PM GMT
    edited 2009-11-30 03:18
    Phil Pilgrim (PhiPi) said...
    Yes, this can make things more complex. But in application I am thinking about, 4 cogs are requirered, and PHSA increment of 16 is perfect.
  • heaterheater Posts: 3,370
    edited 2009-11-30 03:26
    Andrey, the number of COG you have running is not going to influence the timing. The HUB access window always comes around at the same frequency.
    edited 2009-11-30 03:33
    heater, nothing new to me. The access window comes every 16 cycles. PHSA is incremented by 16 from window to window. One long is 4 addressable cells (remeber "2 lsbs ignored" ?). 16 / 4 = 4 cogs, filling a memory region without gaps with free-running counters
    OK now I'm with you.
