Forum moderator question/ or anyone
Let's Go!
Why doesn't Parallax give software·code examples for sensors such as the compass module, and/or all the sensors they sell, ·showing the code for simple movement or action of something such as a motor, servo, light blinking, so customers can assimilate these into·their ideas? "Most", but not all,·of the code given pertains to debug or measure, and leaves lots of potential customers hanging to figure out·what to do after debugging or measuring.·Just wondering.
I suspect many members are not software experts and certainly not as proficient as Parallax software engineers.
The smarter I get, the more I understand I don't know!
Please read, study and learn then go out and do.
- Stephen
Thanks for your reply
(Love that airplane - used to fuel one like it everyday years ago.)
Use PhiPi's forum search tool, you'll find lots of samples or chunks of code - can't say for sure that all the items you're looking for are covered, but I'd be very surprised if they weren't.
http://www.phipi.com/forum/
HTH
- Howard
(the Props that are counterrotating are not made by Parallax, btw [noparse]:)[/noparse]
forum
I think what Parallax gives is more than sufficient. The notable thing about the code that they post is that it will work for anybody who has the device, regardless of the setup (pin numbers may change, but that's not much, and most require a serial connection but that is present in all beginner setups). If they started providing code that does more than show the functionality of the device then they would have to make assumptions about the use of the device, assumptions on what the physical setup is, and so on. Since it is more complex they would then have to provide support for the support.
What you are asking for is not for more documentations on a product. You're looking for completed projects that use the product in a creative way. There's nothing wrong with that, but I don't think it's something that Parallax should provide. The people in the community who create the projects have the decision to open them up and share them or not. Mostly it's a case of just finding the project, which might mean looking further than Parallax microcontrollers.
Finally, a point about software. IMHO, (external) hardware matters less and less the more code that you have. Once you start abstracting, it doesn't matter if your distance sensor is a Ping or a Maxbotics or a Polulu or a Sharp IR or a $10,000 LRF. All that matters is that you have a variable with some value that shows the distance. Once you get to that point then any reflection on the hardware is lost. m2c.
but i would still like to see a light blinking after taking that debug and measurement from the memsis. it would show me how to handle the data with the measurement.it would only speed up the innovtion process for me, and maybe a couple others.
thanks for the input.
Sensors are not meant to blink lights or move servos. All they do is sense something and provide a value. The demo code uses that value by displaying it.
Have you looked at "What's a Microcontroller"? Parallax provides a lot of documentation for using their products. Look here as well.
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
May we all be so good as to create a loyal customer following in our endeavors as Parallax has!
