serial port identification for a Mac — Parallax Forums
Ken  LyonsKen Lyons Posts: 15
edited 2009-11-29 13:42 in BASIC Stamp
The program doesn't give meany ports to select. Help.
    edited 2009-11-27 21:47
    More info?
    - Stephen
  • Tracy AllenTracy Allen Posts: 6,664
    edited 2009-11-28 00:20
    Are you referring to MacBS2? The serial port selection is the bottom item in the STAMP menu.
    Tracy Allen
    www.emesystems.com
  • Ken  LyonsKen Lyons Posts: 15
    edited 2009-11-28 15:16
    It helps when you use the correct USB to serial connector. smhair.gif Now the message I get is "Label is missing." HELP
    edited 2009-11-29 05:44
    So, in your program a label is missing. Usually the compiler will be on the line where it found the error but not necessarily on the line where the error is.
    - Stephen
    Thanks for your response. I retyped the program and checked the syntax and all is well. Go figure.
