Actually, probably what I should have asked was "What code?", but it just seemed obvious. Please, if you want to ask a question, give us a teensy bit of information to work with!
What code, from where? What are you trying to do with it? On what are you planning to do something with it? I mean, really.. Even my girlfriend (who is an expert mind reader) had zero idea what you were asking.
If you always do what you always did, you always get what you always got.
i believe it says its for the PROP BLADE(its the switches driver code).its in the object exchange under HUMAN IMPUT CODE read the topic .
BradC said...
I think you are saying that you are having trouble downloading code from the OBEX because your computer doesn't recognize it?
-Are you running Windows/Linux/Mac?
If you are running Windows, all the files on the OBEX are zip files (to my knowledge), so after you download them you have to extract them. Some of the files do not have the .zip extension so windows won't let you extract it. You just have to add ".zip" to the end of the filename so that it is recognized, and then you can right click and "Extract All".
i got something(at least to me,lol).i downloaded propeller tool 1.2.7 used that to open file and it opened.im new.i was trying to use the iccv7's propeller tool .the prop blade is a pcb by brilldea which uses the propeller P8X32A-Q44 chip to orchistrate leds and dmx.this is my first project.idk
nope still not there the driver code for the prop blade and the led painter opened up with the propeller tool v1.2.7. I dont think the code actually downloaded to the pcb.
So that would suggest it did program the chip OK. Remember if you want the program to be there after the power is turned off and on again you must press F11, this will write the program to the EEPROM not just the propeller memory.
Hope that helps.
Not the fish.
sites.google.com/site/bitwinproject/
Graham
p.s It is input not imput, I only mention it because you wrote it twice and might not know.
Graham
