How to convert applied voltage to pwm
i need to convrt the applied voltage to PWM signal in spin code, does someone know how to do this? The PWM signal as the input to HB-25 (#29144), and i use CJ_HB25.spin at obex.parallax. At thad code i need to identified pulse1 as input PWM pulse to Motor1 and pulse2 as input PWM pulse to Motor2. I need some direction... thanks b4
Best Regards,
