Why is the light not lighting up?
noobmuncher
Hello,
So i have all the components I need and I have built the circuit from the Propeller Labs, however I am running into a problem right off the bat. The led is not lighting up. I have tested everything that the trouble shooting area says to and I am kind of confused. The main thing that I find odd is that across the LED i am only getting 0.12 volts across when old the Prop plug is powering it, yet when i power it with only the 9volt I still only get 0.13 volts. The 9 volt is new and i just tested it, the wiring all seems to be correct ( i have checked and rechecked it) the resister running to the LED is 100 oms 1/4W 5% (brown black brown gold), I have tested several LEDs all of which I have tested on my other boards, both capacitators are 1000 uF 6.3V and the voltage regulators are 5 volts and 3 volts. I have tested it with the led connected without the resistor and i still don't get any light, in fact i only get 0.15 volts.
Any idea what I am doing wrong?
Thanks for any help, problems with circuits are always so frustrating to work with.
Style and grace : Nil point
If that's okay, then you should try just wiring the LED/resistor from 5V to ground to get it to light that way. Be sure to keep your connections away from the Prop pins! In fact you might want to remove the Prop chip while you're testing things in general.
about WHICH LED are you talking ?
The one connected to the powersupply like in the schematic in the attached picture ?
From this schematic you can see that it operates properly from 6V to 9V so 8.5V should work.
If you check the voltages between GND and the 5V-point what voltage do you have ?
If you check the voltages between GND and the 3.3V-point what voltage do you have ?
What EXACTLY did you narrow down ? Does the separate circuit work as expected ?
Do you get the 5V and the 3.3V with the separate circuit ?
best regards
Stefan
