Off-topic: FTP Server speeds
Hi-
I realize this has nothing at all to do with Parallax, but I've seen all the knowledge around here and hope someone might have an idea what's going on. I've got an old P4 Dell running Windows XP, 256MBRAM, 20GB hard drive. I got it for free, so no complaints. I'm using FileZilla server to serve my 1TB drive to the network. The Desktop is plugged into my roomate's Belkin router. Problem is, transfer speeds are ridiculously slow. Internally, I don't get more than 1MB/sec either direction (everything wired) and from the internet I only get 300KB/sec or so.
The Desktop does tell me that it does not support high speed usb ports, but I thought the speedcap on that was alot higher.
We're supposed to have 12Mbps internet, Comcast cable. In the mornings we get up to 20Mbps, in the evenings as low as 1 Mbps [noparse]:([/noparse]
Transfer speeds seem the same at all times.
Any ideas why this setup is so slow?
Rafael
You've got to play the game.
You can't win.
You can't break even, except on a very cold day.
It doesn't get that cold.
~Laws of Thermodynamics~
Rafael
You can't win.
Actually, that would explain alot of things. Everyone in my appartment seems to get exceptionally bad speeds all the time...
Rafael
You can't win.
Post Edited (FlyingFishFinger) : 11/25/2009 9:36:22 PM GMT
Alex Burke
"Beware of computer programmers that carry screwdrivers." -Leonard Brandwein
another thing to check I have a cable modem also is when its at its slowest from your PC go to to the CMD prompt or the DOS prompt and type""" ping www.yahoo.com -t """" no quotes and tell us if you get any timeout errors and what speed shows up in the return.
Then if its timing out and really slow unplug your cable modem and router I mean the power from both not just a reset you need to shut off power from wall outlet so just unplug them ,,wait 1 minute and do the exact same thing again and see if it is any faster after the power on reset.
Why so? For things like an FTP servers, Linux doesn't have to provide the overhead of a Windowed GUI - just operate in terminal mode, no GUI.
Of course that won't help if your ADSL is not providing enough speed. Mine varies, but once I go outside of Taiwan it drops off to a snail's pace. I use a website to monitor it from time to time and it hasn't gotten any better. I pay for 512K/8Gbyte service and I get about 256K/4Gbyte service inside Taiwan.
Try the link below.
http://www.speedtest.net/
In sum, there are a lot of places that can cause bottlenecks. Shutting down IP6 options is a good idea as they add another step to processing for the router, but it is just one of the items. And your ISP may want you to pay for any real improvements in bandwidth (after all, all they have to sell is bandwidth).
If you do go to Linux, you might be able to have the FTP server also be your gateway/firewall in front of the router and eliminate all concerns about a slow router gateway.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
