Micro Bolt Lock
Anyone know of an in-expensive bolt lock like the one here.
http://www.sdcsecurity.com/series.aspx?id=46
either surface mount, or jamb mount (preferable)
These would be nice for keyless access, but a little pricey.·
Either that or a good way to locally fabricate one.
Thanks.
Tia'Shar Manetheren
Thanks.
Tia'Shar Manetheren
But, if you're trying to duplicate a commercial quality lock with fail-safe/fail secure modes for less than the noted $100, I don't think you'll be able to do it.
If its a just a learning exercise, the coil and plunger approach won't break the bank.
You might also be able to adapt a servo or other motor to an existing inexpensive dead-bolt lock.
Cheers,
Tom Sisk
http://www.siskconsult.com
·A better one can be found in some ancient computers that had the key lock function. It was a small selinoid that could lock in either position. Hard to find though!
Do a search on the site for solenoid. I was just in there yesterday poking around and saw these.
www.allelectronics.com/make-a-store/item/SOL-58/24-VDC-PULL-TYPE-SOLENOID/-/1.html
You can get a large variety of 12VDC or 24VDC solenoids for around $5USD each and fabricate your own brackets.
Here in Taiwan, we have a door latch that opens from the outside with a cylinder key, opens from the inside with a button, or remotely with a electrical pulse and I am pretty sure that it doesn't cost $96USD. Very pricey.
Ain't gadetry a wonderful thing?
aka G. Herzog [noparse][[/noparse] 黃鶴 ] in Taiwan
http://www.pololu.com/catalog/category/23 - $9
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
Allelectronics has a dual pole solenoid with separate wires per coil. Wouldn't this allow a voltage on one coil to move it one way, then apply voltage to the other coil to reverse it? I don't think it would require voltage to remain in either state unless I am missing something.
www.allelectronics.com/make-a-store/item/SOL-122/DUAL-OPPOSING-SOLENOID-LINEAR-ACTUATOR-/1.html
Tia'Shar Manetheren
(Unless there is also a crash bar.)
Consider having a locked door, and a fire occurs. Power is lost to the solenoid, so it stays in the locked position. HOW DO YOU GET OUT??
--Rich
(In fact, such a setup may be illegal in your area.)
I'm glad someone raised this. It's for the same reason I won't use a "dropbolt" in any security application. They jam and people die.
Please don't use any home made locking devices on any doors you might need to access in any form of emergency. Saving $100 on a lock is not worth your life.
If you always do what you always did, you always get what you always got.
read RiJoRi's warning earlier today - just a bit before one of our local fire marshals arrived for an inspection.
I mentioned the powered door latch to him - and he asked exactly what RiJoRi said: "so how do you get out if the power fails?"
Accordingly, in every(?) US state such a device is against fire codes (at least for commercial buildings, which are more tightly regulated.)
Those credit card style readers the hotels and motels have do electrically bolt the door --- but from the *outside* only. From the inside, you have to be able to open the door with "one hand motion and a push".
I learned lots about fire codes and doors when I had to remove all 12 doorknob latches from our building to meet code.
These codes exist often because people do dumb things - and the regulators have to then make sure that others don't do the same thing!
Please don't become a statistic!
For myself I would want something like this for locking cuberts or the safe I want to build. In either case I would have a battery backup and it would not be a life or death situation if I could not get in do to power failure of both battery and main power. If you want electronic door locks for your house there are many very nice ones with both key and code entry.
24 bit LCD Breakout Board now in. $21.99 has backlight driver and touch sensitive decoder.
Tia'Shar Manetheren
just goes to show that we were thinking like engineers: think, plan, design for the worst - but get too busy to properly read the specs ... over design ... over budget ...
Client then says - hey I just wanted a "CABINET" lock, not a human-entry lock.
DOH!
(If we'd clicked that link you did provide in the first place, we'd have known better [noparse]:)[/noparse])
cheers,
Howard
