hb25 control of speed, direction,and time
the direction and time of the hb25 is controlled with the for index...next command and the pulsout hb25, 750 (+ or -) index. but how does one control the run·time·w/o affecting the speed?
i.e. how would you command the hb25 to operate the motor slowly, but for a predictable long period of time?
the examples given include ramping up and down for smoother control.
e.g., the for index = 1 to 250 will bring the motor a fast speed and long run time, whereas 1 to 50 will operate the motor slowly, but only for a short time.
thanks for your thoughts
The smarter I get, the more I understand I don't know!
Attach the code you've tried and you'll get more concrete suggestions.
Tom Sisk
http://www.siskconsult.com
PAUSE 20
FOR index = 0 TO 50····· 'ramp up,do this routine until pin 3 goes high, 2" per move
PULSOUT turntable, 750 - index······· 'R to Left, reverse index, short moves
PAUSE 20
NEXT
PAUSE 20
FOR index = 50 TO 0········ 'ramp down, then make pin 3 decision below
PAUSE 20
NEXT
DEBUG ? IN3····· 'will indicate 0 or 1 on pin 3, must run to get debug screen
IF (IN3 = 1) THEN GOSUB reset·· 'after above routine, if pin 3 = 1 then goto reset:
DEBUG ? IN3
PAUSE 30
·GOTO main············· 'otherwise goto main and move tt another 2" to position tt
Judging from the PAUSE length this will repeat every couple of seconds.
Don't quite see where:
"e.g., the for index = 1 to 250 will bring the motor a fast speed and long run time, whereas 1 to 50 will operate the motor slowly, but only for a short time."
What's p3?, what does reset do? is this code "main"? How are you measuring the 2"?
Tom Sisk
'continue forward for 200 pulses at same speed
for pulscount = 1 to 200··· 'sends 200 pulses
pulsout 13, 770·· '200 pulses at "slow" speed, vs 850 which is near·"fastest" speed
pause 20
next
thanks for your time
