Brushless Motor Control
Hello Folks,
I have a question in regards to the Flighttech ESC brushless motor controllers.
From my knowledge, all I have to do is send a pulse using pulsout to a brushless
speed controller to gain control of the brushless motor... (similar to DC control)·
However I am having major problems, the only thing the motor does is beep.·
Is there a different procedure one must follow to control a brushless speed controller?
http://www.technoflight.no/shop/documents/Synergy_manual.pdf
Thank you
Technic-R-C
Thank you
Technic-R-C
Thank you
Technic-R-C
Dave
Dave Andreae
Parallax Tech Support·
If you can run a standard or continuous rotation servo ok and the ESC still doesn't work(with the same code) then you will need to get things up and running with a receiver first. ESC's with a lot of options can some times be a PITA when being run from something other than a radio.
-dan
Arguing with myself--sometimes me, myself, and I don't always agree.
(Former) Caterpillar product support technician
