Shop
OBEX
P1 Docs
P2 Docs
Learn
Events
about the the new x band motion detector — Parallax Forums
toggle menu
Categories
Discussions
Sign In
Register
Sign In
Register
Categories
Discussions
Sign In
Register
Home
Accessories
robot maker
17
2009-11-24 22:42
edited 2009-11-26 00:35
in
Accessories
i just got the x band motion detector in,and wanted to know how do you mount it,does the 2 boards come apart to access the the 2 holes
dandreae
1,375
2009-11-25 14:58
edited 2009-11-25 14:58
The boards don't come apart.
You can use 3/4" 4-40 screws to go through the motion detector for mounting.
Dave
Dave Andreae
robot maker
17
2009-11-25 20:12
edited 2009-11-25 20:12
if i place inside a plastic box with a cover,will it effect the output of the sensor
also test point is it analog
SRLM
5,045
2009-11-26 00:35
A plastic box is practically invisible to high frequency radio waves. Alternately, if it works through walls than it should work through plastic.
www.parallax.com/Portals/0/Downloads/docs/prod/sens/32213-X-BandMotionDetector-v1.1.pdf
Sign In
Register
to comment.
Dave
Dave Andreae
Parallax Tech Support·
