MCP3208 vs FSRW.
Hugh
As per this post, what has been working until recently failed today, the symptom being that the SD card wouldn't mount.
I have the following objects:
- FullDuplexSerial
- Debug_Lcd_AMC1602" ' This is the LCD display
- fsrw ' This is the SD card on which data is recorded
- simple_numbers ' This object handles simple numerical operations
- FloatMath ' This object deaks with the complex floating-point math
- MCP3208 ' This is the ADC object used to deal with the accelerometer data
- FloatString
As of today, if the MCP3208 object is started the SD card won't mount. I can comment-out other objects and it still won't mount - it is only the MCP3208 object that causes the problem. Yet yesterday the exact same software and hardware worked!
Could I have a duff area of RAM? If anyone has any other bright ideas regarding FSRW and MCP3208 I'd love to hear them!
Thanks in advance
Hugh
Hugh - the thinking woman's Geoffrey Pyke.
- FullDuplexSerial
- FloatString
Thanks in advance
Hugh
There is nothing inherent in either the FSRW driver nor the MCP3208 driver that would cause it to suddenly stop working on its own. In addition, it is extremely unlikely that an area of RAM could fail or, for that matter, an area of EEPROM or other ICs or portions of them. It's much more likely that there's a bug somewhere in your program that has somehow corrupted part of your SD card. Have you tried mounting that on your PC? Have you tried running a disk repair program against your SD card?
If you want specific help, you will have to create an archive of your source code using the Propeller Tool, then attach the archive to another message using the forum's Attachment Manager.
There might be bugs in any of the objects you've included. It's unlikely that there's a bug in FSRW only because it's been in use for a relatively long time and there haven't been new problems showing up. The MCP3208 driver is relatively new. Most likely the problem is in your code. That's the way these things work.
Post Edited (Mike Green) : 11/24/2009 9:13:18 PM GMT
r:= \sdfat.mount(3)
I've had cases where the abort-return value got lost when I didn't.
When you do that, you should get a descriptive error code that should help debug this problem.
The SD card works in a PC, has been reformatted as a precaution and·'FSRWTest' runs fine, returning '0' as an abort code and writing/reading data correctly. I have even replaced the Parallax Micro SD breakout board with a Sparkfun SD·breakout board·and the results are the same.
The first symptom was an occassional need for a re-boot to get the card to mount. This became a more-frequent need until it now won't boot with the MCP3208 object present.
If I comment out all of the code except that which starts the MCP3208 object and the SD·'mount' command it won't boot.
If I reverse the order in which the MCP3208 object starts and the SD 'mount' command is called, it still won't boot.
I'm at work, so can't attach the code, but it should be [noparse][[/noparse]url=http://forums.parallax.com/forums/attach.aspx?a=36622]here[noparse][[/noparse]/url]
If I change tab to the 'FSRWTest' code and load that the mount works immediately and returns '0'.
Maybe you could put an empty "repeat" just past the "mount" call to force the program to halt after it displays the mount return status.
Then go into the FSRW code and start plugging in your own unique "abort" code, like "abort(-666)" to show you where things succeed and where they fail.
Start by adding your abort call at the beginning of the "mount" code, to verify that the code correctly captures and displays your "-666", then start moving the abort(-666) around inside the "mount" code until you find the place where "mount" stops working properly.
Both objects are working now, but the SD data isn't right: as per the attachment, the file I want (Data3.csv) is there as a 0KB file, accompanied by many 1KB files. Even the volume label has been mangled to ASCII.
I am mounting the SD volume, opening a file for append, writing to it and then closing it. Would the sliced-and-diced data suggest anything? I know nothing about SD cards.
TIA
Hugh
I had a problem running the FSRW 2.4. I simply tried it with the test-code and got read errors. Test code stops then.
It turned out that I have a different setup in sense of the pins I attached the SD card to. Different pins means different path-length from COG to pin. The path length seems to affect the capacity so much that the timing is no longer correct. I simply replaced the COGNEW with a COGINIT( 7 ... ) and everything works since.
I'd suggest to load the SD driver as first and replace the cognew with a coginit. That way you can test some different COGs. Maybe you have the same problem.
Format the card before doing additional tests. If directory looks so bad cluster table can't look much better.
NYC Area Prop Club
Prop Forum Search (Via Google)
If you would like to email me your code (this user name at gmail.com), I'd be happy to look over it. Also, if you could email me a snapshot of the relevant portion of the schematic, I can look over that as well.
Jonathan
lonesock
Piranha are people too.
I'll have a play with the code and the resistors and then if I need to, take Lonsock up on his kind offer.
Cheers
Hugh
To eliminate wire-lengths and resitors as a possible casue I replaced the extant Parallax micro-SD board with a brand-new one - this time soldered directly to the protoboard. There was no change, but I did observe that rather than it being a case of the code either running or not-running, there was a tendency for the first upload of a day to work. Also, if I sat there pressing F10, out of twenty uploads two or three might be successful. I've grafted things onto a new protobard anf will take things from there - so far, so good....
I will build this tonight and upload it for you; can you test it after that? I think it is not impossible that we are pushing the
edge somewhat in the one-bit-per-clock code. Note that write rates are unaffected.
In any case, the "slower" SPI layers should work fine, as long as you don't need the blazing speed of the default one.
Thanks Tom,
I can't test it on the old board, but will willingly test it on the new version. FSRW is off my list of suspects! Between micro SD cards, SD cards, micro-SD cards in adapters and all flavours inbetween it has done 'exactly what it says on the tin'.
Hugh
I have a piece of code and a lot of objects in a single directory. As I tweak the code and upload new versions "something" happens, after which the SD card just won't mount - nothing is returned from the 'mount' call - it just sits there. Re-formatting the card or using new cards has no effect. I then remove all references to the MCP3208 object in the code and the SD card will again mount. (This is where we came in at the original post in this thread).
However, if download a new version of FSRW (I am toggling between v1.6 and v2.6) everything works again, even with the MCP3208 object re-instated. After a while the SD card fails to mount again. I then change the version of FSRW and everything works...
I am trying to determine whether changing other objects has a similar remedial effect when the SD card stops mounting. Regressing to previous versions of the code (that I know work) will not enable the SD card to mount - only updating the FSRW files in the directory has the 'silver bullet' effect.
Any ideas? Is this down to a fundamental mis-understanding of the Propeller Tool on my part?
The code isn't elegant but is attached for anyone who wants to try and reproduce this. (The location of the FSRW object in the OBJ list has no effect).
Post Edited (Hugh) : 12/15/2009 8:55:48 PM GMT
