MOSFET help
MOSFET help
When using a MOSFET and its turned completely "on" how do I find the "Resistance of the Drain to Gate"? In other words: I want to use a MOSFET that is rated at 7amps continuous but has a power rating of 1Watt. This is drawing some concern for me because I intend on running 12-13Volt supply. I personally think that the MOSFET will be fine because the resistance will be next to zero so, the power dissipated should be relativity small. Am I correct? Please teach me...
www.fairchildsemi.com/ds/ND/NDT451AN.pdf
