ultrasonic sensor
Hello!
Does anyone know how to convert the output signal from the PING ultrasonic sensor into a 0-5 volt or 4-20ma signal.
I want to connect the PING to one of my industrial P.L.C.s.
Thanks for the help and your time.
I have a bs2p and a boe.
Where do i find source code for that?
The BASIC Stamp Syntax and Reference Manual chapter on the PWM statement will show you how to use the PWM statement to generate a voltage given a number. You may need an op-amp buffer if the PLC input is not a high-impedance input.
The Manual can be downloaded by going to the main Parallax webpage and clicking on the Downloads tab, then the "BASIC Stamp Documentation" link.
