What is the interest in an SX module?
After these few months of time away from these wonderful forums due to mounds of schoolwork, I was struck by an idea to create a now much needed module for the SX chip now that there are only surface mount SX chips left.
What would be the interest in a low cost (say, $20) module that comes pre-built with SX and peripherals so you only have to plug in your key/blitz and around 6 volts to start programming?· I have been refining the board layout and will place an order, probably over christmas break.
Thanks for your feedback.
Quit buying all those fixed voltage regulators, and·get an Adjustable Power Supply·for your projects!· Includes an LED testing terminal!
*-NEW-* SD Card Adapter·Now available!· Add extra memory to your next Propeller project with ease!
For the SX48 I have a board that works out well as a carrier for the chip or can be built up as a whole module. It is shown in this thread which was just updated with the docs:
http://forums.parallax.com/forums/default.aspx?f=7&m=194701
It might give you some ideas if you decide to make something similar for the SX28.
Robert
I understand sort of how you can buy circuit boards and photo etch them but the holes are so close and small how do you do that?
thanks
I don't think I'm ready to post my board layouts, but after I get a prototype and order some boards, I most likely will.
I hope that helps.
We're moving along to the SX dip pkg device because I don't think we can get the features needed in the BS2xx series. If you're building SX28/48 modules, I'm interested to know more!
Feature request - what would really be nice is a:
24pin (or 28pin) 600mil dip pkg,
with BS2 compatible pinout (could even add a BS2p40 compatible model),
that runs at 3.0~5.5V Vdd
(Vin = Vdd+0.4V to 9V or 12V),
4~50MHz,
adjustable (or solder replaceable) threshold reset generator,
with on-board 64Kb~256Kb 1MHz SPI RAM (Microchip 23K630 or 23K256)
and native SX/Basic instructions to access the RAM.
128Kb 1MHz serial EERPROM,
SX-Key connectivity
Serial in-circuit reprogramability.
If it could be loaded with the Parallax BASIC interpreter, it would be like a BS2px-Enhanced product!
Curious, if you're etching protos yourself, are you actually doing 5mil traces and 0402 parts?? My limited garage etching experience could not turn out reliable 5mil traces...
-- BrooksL
Wow--sounds like a good module idea to me! Some of those things are a no-brainer, but I don't know about cramming that sram onto a tiny board...
When I posted this, I was intending to order the boards from expresspcb. Now, however, I think I could etch them.
Also, I would probably be using 0603 parts. They give a little more leeway with the sharpie.
Happy holidays.
