3.3V sensor to 5V ADC
Hi there!
This isn't specifically Basic Stamp Related, but I figured somebody here would be able to help.
I have some 3.3V sensors with analog outputs that I would like to interface to a 5V ADC converter, while maintaining full resolution. ie, I don't want to just give up the range of digital values generated between 3.3V an 5V. An example of one of these sensors is a 3 axis accelerometer, with an analog output for each axis. You can view the data sheet here: pdf1.alldatasheet.com/datasheet-pdf/view/103487/MOTOROLA/MMA7260Q.html
The ADC expects a value between 0 and 5V volts (analog), so if I just send in the 3.3Vmax signal, I'll be wasting valuable resolution. How can I proportionally amplify the 3.3V sensor output so it ranges from 0 to 5V?
Thanks so much!!!
I can haz propeller chip?
Thanks so much!!!
http://www.trossenrobotics.com/p/Bioloid-IO-Board.aspx
However, there is a 5V regulator that powers the sensors, which could easily be replaced with a 3.3V regulator. perhaps I'll get lucky and that reg is hooked up to the reference on the ADC as well. If not, looks like I'll be cutting some traces...
- Stephen
You are correct, this Subject doesn't belong in this area at all.
Look for a datasheet for an LM358, it's a dual op-amp designed for use with single-ended (+V and GND) supply.
Dave
Dave Andreae
Parallax Tech Support·
