Battery Voltage Drop Detection
I am powering a Basicstamp1 directly(no regulator) with a 9Volt alkaline battery and·same battery·is driving a H bridge to run a DC Latching Relay. When the battery voltage drops to about 6 volt I want Basicstamp not to drive H brige anymore. I tried to use a zenner diode to detect voltage drop but I havent been successful yet. One of the problems I have, I dont know what are the voltage limits for an Input Pin, I mean at what voltage it is 1 and 0. If zenner diode doesnt work is there anyother way to detect voltage drop.
Roni
Roni
Keep checking the pin in software, as long as it is high, you have 6 volts or more. Low means under 6V.
home.cogeco.ca/~rpaisley4/Comparators.html
