Question for ya
I have been going through the documentation for the propeller, and I have a question. Some of it talks about the prop using a "software" based I2C. Now, if it's software based, does that mean any of the IO pins could be used for the SCL and SDA pins? Is there something special about pins 28 & 29?
The only reason I ask is out of curiosity. I'm no EE, so I didn't know if there's a physical difference in the silicon that mandates I2C is on pins 28 & 29 only.
Everything I've read says that the props are hardcoded to look for the EEPROM on 28 & 29 for boot, but I didn't know if there's something special about those. And that makes me ask another question. Since all the serial apps have start methods that specify pins 30 & 31 for serial communications, does that mean theoretically you could use any two pins for serial?
Sorry if I'm rambling, my mind wanders a little too easily.
JW
JW
I'm no EE either, but I tried using a couple of other pins (just because they were in the neighborhood), and went bananas trying to figure out why they weren't working, until I posted to the forum and someone walked me through it. That was over a year ago, and I can't find the thread now, but it was extremely helpful. Hopefully one of those folks will chime in here and explain it again: I could use a refresher.
Post Edited (sylvie369) : 11/21/2009 8:55:14 PM GMT
Most of the I2C I/O driver software in the Propeller Object Exchange is written to use any pair of I/O pins for I2C.
