Driving LEDs from logic output of the DS1620 thermostat — Parallax Forums
jessicajessica Posts: 8
edited 2009-11-21 22:06 in Propeller 1
Hello
I'm a propeller user and I·would like to know please what are the most appropriate mosfet or transistor to use
to drive Leds from the TCOM, TH and TL output of the DS1620 thermometer.
Because if I drive the led directly from the output the DS1620 is overheating and so
as noticed on the appnote I·need a buffer like a mosfet or a darlington to operate the led properly.
I only know a few things about those parts and I don't know the best one to sue.
thanks a lot for your help and excuse me for my english (i live in france)
jessica
  • LeonLeon Posts: 7,620
    edited 2009-11-21 18:00
    Did you put a current-limiting resistor in series with the LED? You could try a high-brightness LED with a 1k resistor. That should be bright enough and won't provide much of a load.
    Leon
    Amateur radio callsign: G1HSM
  • jessicajessica Posts: 8
    edited 2009-11-21 21:36
    Thanks for the advice.
    It works fine, the DS1620 is not heating so much but I think I can't escape using a mosfet or a transistor if I want to drive a 12v fan for example ...?
    I dont know exactly what kind of precise components to use ?
    thanks for help ?
    The outputs of the DS1620 will sink 4mA or source 1mA. I suggest you use an NPN Darlington like an MPSA14 or equivalent. This will switch 500mA at up to 30V. You'd want a base resistor of 3.3K to 10K.
