ICCProp Program dosen't start — Parallax Forums
ansst5ansst5 Posts: 4
edited 2009-11-21 17:57 in Propeller 1
I decided to try out the ICCPROP IDE with the Propeller Education Kit and have ran into a problem. I launched the example project, blinkLED.c.· It complied and·appeared to download ok but the program doesen't start.· I've tried a couple other ICCProp example projects and they won't start either. I tried an example spin project and it·runs fine. Has anyone else ran into this problem?· Thanks·
  • LeonLeon Posts: 7,620
    edited 2009-11-21 15:03
    I tried that blinkLED.c example with the Proto Board and it worked OK.
    Leon
    Amateur radio callsign: G1HSM
  • ansst5ansst5 Posts: 4
    edited 2009-11-21 16:18
    Thanks for your reply Leon.
    I tried a proto board with the same results.
  • Nick MuellerNick Mueller Posts: 815
    edited 2009-11-21 16:36
    Did you select "Load and run"? Or the like.
    Nick
    Never use force, just go for a bigger hammer!
    The DIY Digital-Readout for mills, lathes etc.:
    YADRO
  • JavalinJavalin Posts: 892
    edited 2009-11-21 16:59
    Did you open a project or just a "c" file? The former works, the latter doesn't.
    James
    I think that caught me out when I tried it. It was some time ago, though.
    Leon
