watchdog in propellor
hi
i am new to propellor, and i am just getting to know it. Could anyone please tell me how a watchdog timer is implemented on a propellor?
Regards
Regards
Leon
Amateur radio callsign: G1HSM
Post Edited (Leon) : 11/21/2009 12:49:09 PM GMT
Leon
Post Edited (Leon) : 11/21/2009 2:15:36 PM GMT
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
@faizzz: the propeller haven't a hardware watchdog. But if in place of the standard 32K eeprom you use the FM31L278 (ramtron) in a single chip you have 32K un-wear-able fast-write eeprom substitute, a hw watchdog, a RTC and other features
PEdit: BTW many times watchdog haven't special software retrigering them, the triger pin is just wired on the data or addres bus thus monitoring bus activity.
· Propeller Object Exchange (last Publications / Updates);·· Vaati's custom search
Post Edited (dMajo) : 11/21/2009 7:21:15 PM GMT
By dedicating a cog and an I/O pin that connects to the prop reset pin you can have a watchdog timer for the remaining cogs. Each remaining cog has a hub memory location that it must set to a specific value to prevent the watchdog cog from resetting the prop.
