Boe-Bot RFID Problems
Hello all,
Recently I've been using the RFID Card Reader Serial (Item code 28140) and I keep having some problems.
What I think as being the problem is that the RFID reader "waits" for an RFID tag to be shown. Well I dont want that
The boe bot should do the following:
Ride, forward.
IF a wall is close up, trun.
IF an RFID tag shows up, go backwards. (this is not in de code, because the first thing wasnt even working yet)
ELSE ride forward.
Here's the code I've been using:
If you have some suggestions on how I can "replace" the SERIN (the waiting function) with an IF-alike code, I'd really like to hear it.
Thank you very much!
- Animal
Ride, forward.
ELSE ride forward.
' {$STAMP BS2}
' {$PBASIC 2.5}
n VAR Word
SRF05 PIN 6 ' use any pin for both trigger and echo
Range VAR Word ' define the 16 bit range variable
DO
SRF05 = 0 ' start with pin low
PULSOUT SRF05, 5 ' issue 10uS trigger pulse (5 x 2uS)
PULSIN SRF05, 1, Range ' measure echo time
Range = Range/29 ' convert to cm (divide by 74 for inches)
PAUSE 10
DEBUG CRSRXY, 0, 4, DEC Range, CLREOL
Enable PIN 0 ' low = reader on
RX PIN 1 ' serial from reader
T2400 CON 396
Baud CON T2400
LastTag CON 3
buf VAR Byte(10) ' RFID bytes buffer
tagNum VAR Nib ' from EEPROM table
idx VAR Byte
char VAR Byte ' character from table
Tag1 DATA "24008C67A2" ' valid tags
Tag2 DATA "24008C6C7D"
Tag3 DATA "24008DE3CB"
Name0 DATA "Koprol", CR, 0
Name1 DATA "Fwd", CR, 0
Name2 DATA "Left", CR, 0
Name3 DATA "Right", CR, 0
Reset:
HIGH Enable ' turn of RFID reader
Main:
LOW Enable ' activate the reader
SERIN RX, T2400, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID
HIGH Enable ' deactivate reader
Check_List:
FOR tagNum = 1 TO LastTag ' scan through known tags
FOR idx = 0 TO 9 ' scan bytes in tag
READ (tagNum - 1 * 10 + idx), char ' get tag data from table
IF (char <> buf(idx)) THEN Bad_Char ' compare tag to table
NEXT
GOTO Show_Name ' all bytes match!
Bad_Char: ' try next tag
NEXT
Show_Name:
LOOKUP tagNum,
[noparse][[/noparse]Name0, Name1, Name2, Name3], idx ' point to first character
DO
READ idx, char ' read character from name
IF (char = 0) THEN EXIT ' if 0, we're done
DEBUG char ' otherwise print it
idx = idx + 1 ' point to next character
LOOP
FOR n = 1 TO 1
PULSOUT 14, 650
PULSOUT 15, 850
NEXT
IF Range < 20 THEN
FOR n = 1 TO 50
PULSOUT 14, 650
PULSOUT 15, 650
NEXT
ENDIF
ENDIF
LOOP
- Animal
buf(0) = $FF ' make sure tag can't match if times out
SERIN SERIN RX, T2400, 100, continue, [noparse][[/noparse]WAIT($0A), STR buf\10] ' wait for hdr + ID
continue:
This will wait at most 100ms for a character, then continue
