Code
Hi my program is not completely executing my exact instruction set. I want it to check two sensors and if the difference of the two sensors is greater than a certain constant assigned then make the move instructed. My code attached only compares the sensor and whenever there is a slight difference it execute. :
bs2
6K
It looks like the values you are shifting to the ADC have been changed from the original program; which is what sets the mode and channel you are reading in. For example, if you are want to read Channel 0 in a single ended mode, you could use the following:
· LOW CS
· SHIFTOUT DataIn, Clock, MSBFIRST, [noparse][[/noparse]%11000\5 ]···· ' Select CH0, Single-Ended
· SHIFTIN DataOut, Clock, MSBPOST, [noparse][[/noparse]result0\13]·· ' Read ADC
· HIGH CS
From there, you could change the last two bits accordingly to select the channel you would like. In the datesheet there is a truth table that will explain how to use this function; so you can make sure you have the proper channels selected to get the inforamtion from?
Respectfully,
Joshua Donelson
www.parallax.com
There are at least two problems with this. For one, you're using "&" which is a bit-wise AND operation when what you need to use is "AND" which is a logical test. Look in the BASIC Stamp Syntax and Reference Manual for a more detailed description of these operators. You can also look in the help files of the Stamp Editor.
The 2nd problem is that you're testing for equality between X1 - X0 and V. Is that really what you want?
I think what you want is: IF ABS(X1 - X0) > 400 THEN
