Capacitors for voltage regulators
kt88seamp
I am building a·5 and 3.3 volt power supply for a ft232rl chip and a propeller. The 3.3 volt·via the propeller will power a moc3010 triac driver along with the prop's eeprom. The·5 volt powers only·the ft232rl.·A transformer 120V to 12V (center·tapped)·via a rectifier will drive·both regulators in parallel.·What equation should I use to calculate the·regulator input capacitor(s) and also the caps off the output pins on each regulator·(if any are needed). The regulators I am using are these:
AME8800SEFTZ series·(5 volt and 3.3 volt)
Both are available on Mouser.
http://www.mouser.com/ProductDetail/AME/AME8800AEFTZ/?qs=sGAEpiMZZMuLLNXTG1MZalY17qJmshbySy2ZD%2f4V1iw%3d
http://www.mouser.com/ProductDetail/AME/AME8800SEFTZ/?qs=sGAEpiMZZMuLLNXTG1MZapp2Mh8OgVzFTOA7GVxV7cU%3d
The input capacitor provides local storage of energy when the regulator is at some distance from the power source and when there is sufficient resistance and inductance in the supply wiring that a sudden demand for power will be found wanting. I suspect that the Propeller lab circuit used a 1000uF capacitor at the input of the 3.3V regulator because it's really the output capacitor of the 5V regulator. There's not a lot of need for an input capacitor that large, even when the regulator is at some distance from the power source.
The output capacitor provides local storage of regulated power and you can roughly compute the amount of capacitance needed from the amount of current drawn by the load (Propeller, peripherals, motors, etc.) and the amount of time you want to keep things running. A 1000uF capacitor is reasonable if you're going to try to drive a motor or solenoid or relay where the instantaneous current demand may be an Amp or more.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Rich H
The Simple Servo Tester, a kit from Gadget Gangster.
A 47uF input capacitor is probably ok, but you may need the small (0.33uF) capacitor anyway. Again, the datasheet should discuss this if it's an issue.
Here is the datasheet for the regulator I'm using. I'm not seeing much discussion about capacitors in it.
Rich H
Rich H
·To me the part that are in blue are the important thing to keep in mind when using this regulator
The AME8800/8811 is stable with an output capacitor
to ground of 2.2mF or greater. Ceramic capacitors have
the lowest ESR, and will offer the best AC performance.
Conversely, Aluminum Electrolytic capacitors exhibit the highest ESR, resulting in the poorest AC response.
·Unfortunately, large value ceramic capacitors are comparatively expensive.
One option is to parallel a 0.1mF ceramic capacitor with a 10mF Aluminum Electrolytic.
The benefit is low ESR, high capacitance, and low overall cost.
A second capacitor is recommended between the input and ground to stabilize VIN.
·The input capacitor should be at least 0.1mF to have a beneficial effect.
All capacitors should be placed in close proximity to the pins.
·A "Quiet" ground termination is desirable.
This·can be achieved with a "Star" connection.
··Thanks for any··that you may have and all of your time finding them
Sam
Post Edited (sam_sam_sam) : 12/9/2009 1:55:22 AM GMT
