How Satellites avoid breaking up in space due to cold temp ?
That is basically the question I have been having for a while.
If I submerge a piece of something in liquid nitrogen (-196 °C) and hit it, it breaks. The how do they keep things from breaking in space where the temp is around -270 °C ? Do they keep _everything_ every piece of pipe, wall and so on thermalized ?
Visit some of my articles at Propeller Wiki:
MATH on the propeller propeller.wikispaces.com/MATH
pPropQL: propeller.wikispaces.com/pPropQL
pPropQL020: propeller.wikispaces.com/pPropQL020
OMU for the pPropQL/020 propeller.wikispaces.com/OMU
Post Edited (Ale) : 11/19/2009 12:15:31 PM GMT
If you always do what you always did, you always get what you always got.
I suspect the reason why some satellites are in low orbit is because they are using the Earth as a shield to make them last longer.
24 bit LCD Breakout Board coming soon. $21.99 has backlight driver and touch sensitive decoder.
So that leaves radiative thermal transfer. Anything above absolute zero emits thermal radiation. That include clouds of warm gas, planets, stars, etc. Thermal transfer via radiative processes takes into account the sum of thermal energy received from the environment minus the sum of energy lost from your object. In other words you have photons leaving your object and other photons hitting your object, and the resulting sum of photons lost and gained is what will determine if your satellite is going to heat up or cool down.
Now let's say your satellite is floating infinitely far away from any planet or star, and it is wrapped in a black blanket that perfectly absorbs all photons and is forever stuck at absolute zero. Such a blanket would emit no photons, so the satellite would get nothing from this blanket. The satellite, however, would be emitting photons that the black blanket would perfectly absorb. Over time, if there are no energy sources inside the satellite, the satellite would approach the same temperature of the blanket, absolute zero.
You can think of the cosmos as being that black blanket, except instead of being at absolute zero, there is a background energy that was left over from the Big Bang (plus star light, etc). The photons streaming in from all directions makes the cosmos appear like a black blanket at a few degrees above absolute zero, so from the standpoint of radiative heat transfer, the cosmos "looks" like roughly -270°C or whatever.
Of course, if your satellite is floating around in sunlight, that's a whole different story. It will be awash in photons, and because the satellite has nothing to conduct away the incoming thermal energy, it must rely on reflective shields and, sometimes, heat transfer systems that pick up the energy from the hot side and pump it to the cold shadow side where it can radiate the energy into the black blanket of space.
Keep in mind that if you were wearing a thin glove and reached out and "touched space", it wouldn't necessarily feel cold. Much would depend on whether your glove were in shadow or sunlight and on how good of an insulator the glove material happens to be and whether or not it is reflective, etc. You'll notice space suits don't come in fall fashion colors.
hope that helps,
Mark
Oops, of course, I forgot to mention that it's a satellite of the Local Group.
en.wikipedia.org/wiki/Local_Group
Just like anything else: Duct Tape, Chewing Gum, and Velcro (especially Velcro)
John R.
Click here to see my Nomad Build Log
