RamBlade - Any interest in a through hole version pcb??
Now that the RamBlade (SMT) is done and awaiting pcbs/parts, is there any interest in a through-hole version (microSD is SMT) ??
Specs would be similar to the RamBlade...
·RamBlade: Prop+SRAM+microSD addon to run ZiCog/CPM/PropDos/Catalina, etc
·http://forums.parallax.com/showthread.php?p=849265
RamBlade T/H
There·are a few differences to the RamBlade SMT version...
Possible·options...
Estimated prices US$ ...
So, the questions are...
The reason I ask is there are a lot of people following these types of·threads. The TriBlade pcb was very expensive to produce so at $25+shipping it was a loss to me. I still have a few pcbs but I do not expect to get any more done.
· Emulators: CPUs Z80 etc; Micros Altair etc;· Terminals·VT100 etc; (Index) ZiCog (Z80) , MoCog (6809)
· Search the Propeller forums·(uses advanced Google search)
Post Edited (Cluso99) : 11/19/2009 5:04:57 AM GMT
RamBlade T/H
- Propeller (80MHz) - also designed for overclocking (96MHz/104MHz/114MHz/120MHz???)
- 512Kx8 55nS SRAM
- microSD socket
- AT24C256/AT24C512/AT24C1024 (32/64/128Kx8) EEPROM (optional - prop can be downloaded)
- Designed to run ZiCog & CPM, and/or other Propeller hosted operating systems.
- 2 pin serial interface to the outside world (see below)
- Designed to either....
- plug into another (host)·Propeller board (Proto, Demo, etc) or another micro based processor
- plug into the Prop ProtoBoard (USB or non-USB), DemoBoard, SpinStudio,·and other cpu boards·
- plug into a PropPlug and PC
- Optimised for speed - No latches
- Connector the same as RamBlade SMT (but SI & SO are the same as prSI & prSO)
- PCB size about 2"x3" (50mmx75mm)
- Slightly slower ram access because of simpler·circuit
- Uses P30 & P31 as the serial and programming pins (more standard)
- Eeprom does not require disabling
Possible·options...
- Bare pcb
- PCB + pre-soldered SMT microSD
- SRAM chip 512Kx8 (not soldered)
- AT24C512 preloaded with SD boot code (boots from microSD card) (not soldered)
- microSD card preloaded with ZiCog/CPM2.2
- maybe xtal and prop chip (unsoldered) ??
- PCB $5, soldered microSD $5, SRAM $5, AT24C512 preloaded $5, microSD 1GB/2GB card $20
- Shipping would be by unregistered airmail and cost US$5
- Is there enough interest for me to do the pcb ?
- Are parts required ? It costs me a lot for shipping and I don't want to be a shop - it's a hobby.
- Would this allow more of you to get into CPM or other external memory programs ?
Naah - forget it. Too much work.
JMH
JMH
I'm shipping some stuff (including parallax stuff) from my Texas mailbox in the next week or two . Your parts can hitch a free ride if you like
cheers
tubular
Thanks. It seems that everyone likes the preassembled SMT version. So I will give this a miss for now.
