How to get the reading from a thermopile — Parallax Forums
JohnnykhorJohnnykhor Posts: 6
edited 2011-04-19 16:18 in Accessories
hi everyone,
i gotten a thermopile lately, and·i fail·to get the reading (output) from the output pin.
i connect the +5V and GND according to the datasheet, and i try to measure the output pin, but i only get a 2.5V constantly no matter where i direct the thermopile to.
can anyone tell me that the thermopile needs some application circuit for it?
thank you very much!
    edited 2009-11-18 21:36
    Maybe if you provide a link to the data sheet or at least a part number, somebody will know what you're talking about.
  • saadsohailsaadsohail Posts: 1
    edited 2011-04-18 00:37
    I'm having some related problem, i bought a TP302 thermopile IR temperature sensor from local electronic shop, but couldn't find any spec of it on the internet, can anyone help me in this regard?
    thanks
    edited 2011-04-18 10:55
    This is all I could find http://www.datasheetarchive.com/pdf-datasheets/Datasheets-310/111964.html Not the same part but there are some circuits on the last page. Could you attach a copy of the datasheet you have?
    A thermopile is a millivolt generator. You don't hook it up to 5V. It generates a voltage proportional to the temperature, a few hundred millivolts when it gets heated by a gas furnace pilot light.
    What's your application and where is your data sheet?
