Time keeper DS1302+Parallax serial LCD
I have a bug when I try to set up the date of the DS1302 with the LCD. I am getting hexa numbers with the decimal numbers on the LCD screen. I think I have tried everything to solve the problem but I am not good enough and I need some helps. I attached the code. I am using only one pushbutton and an accelerometer to do the job it's why you get some ">" and "<" instead of "=0" or "=1". The sub "ReglageHeure:" is where the code to set u^p the time is.
Thanks for your help
PS I only left the code concerning the bug because the all code is closed to the maximum for the BS2
Chris
Chris
